2011 Blade Standard bits
Discussion in 'Wanted' started by R1X, Nov 26, 2013.
  1. R1X
    R1X New Member
    Hi!
    I am after a standard set of brake/clutch levers and the original chain adjuster blocks please!
  2. Skippy79
    Skippy79 Active Member
    contact yorkshiregooner, he'll have them for sure
    index
  3. f1nn
    f1nn Active Member
    I've got them, based in Berkshire but travel to Surrey often with work.
  4. BlackDevil
    I got all the original parts as well............
  5. Racer38
    Racer38 Active Member
    Sorry to hijack the tread, but need these too. I'll try PMing you
  6. Racer38
    1 more post and then I can PM
  7. callumw
    callumw Active Member
    I have a stock clutch and brake lever, but the brake lever has some crash damage after my highside last Jan.
    It's not bent or anything ... the bobble bit at the end ground down a wee bit. Other than that it's fine.
    Let me know if you're interested
