  1. GH02T
    GH02T Active Member
    today i was cutting about 5" off my front fairing to fit my FAT BAR conversion
  2. Pete H
    Pete H Active Member
    Fitted some osram nightbreakers, so hopefully I can see what crap road surface is about to try and take me down on my commute.
  3. Souleh
    Souleh Active Member
    Fitted some bits as per new 2014 racing regs here!
    Brake guard!
    Built a wee bracket from an old tail tidy to hold a rain light
  4. Hondaboy63
    Hondaboy63 Active Member
    Been a wee bit busy.
    Also installed new floating discs brembo style.
    Installed my clutch lever harris style and changed the lever on the brake. image.jpg
    Only issue I can't work out how to attach the reservoir bottle to the new brembo M/C.
  5. arthurbikemad
    You can use the OEM res, but you have to cut the mount and reshape it, then mount it to the upper m6 clamp bolt like the Brembo kits, tbh it works well and even uses the OEM pipe too. I do this with a few including this one here if you can see it.
    Hi res: http://www.myalbum.co.uk/GroteFoto-6HZU7CLI.jpg
    Same setup only with Oro discs (Oro is Italian for Gold so I'm told) this was a track bike conversion I did last month.
  6. Nutty Tart
    Nutty Tart Well-Known Member
    I drilled the top yoke and put a bend in the bracket supplied with the pot
  7. ray
    ray Well-Known Member
    That's not just any track bike conversion Arthur ;)
  8. si1000repsol
    Received my breather kit and alloy tank today. The tank weighs next to nothing![​IMG][​IMG]
  9. Skippy79
    Skippy79 Active Member
    That's some serious porn there Si ;)
  10. Jamiestrada
    Very very nice SI
  11. bradt
    bradt Elite Member
    Took the pillion pegs of my Repsol rr9 today, very pleased with the result, it looks so much better, and was not as difficult as I thought (thanks to paulbusdriver) for his detailed instructions on the forum.
    #2751 bradt, Dec 10, 2013
  12. t0m541
    t0m541 Senior Member
    Yes I took mine off my rr7, doesn't take long at all with a decent cutting disc in the angle grinder :D
  13. sps170373
    Where did you get them from Kev?
  14. Barstewardsquad
    Bought the last replacement bit to put on the bike if I ever decide to sell her.
  15. Jap_STi_3
    Jap_STi_3 Member
    Fitted my Garmin Zumo 360 Well chuffed as it only took 30 minutes from start to finish. Got to admit I'd already fitted the. Ram mount in the headstock hole. I'm happy with the location and can adjust it once tank bag is fitted. That's my next job. Petrol cap mounted tank bag.
  16. Skippy79
    just picked up my power commander 5, BMC race filter and a new starlane laptimer… now all I need to do is shake off theis cold so I can get cracking on fitting it all….. Also got a HM Quickshifter, GM covers, Gilles rearsets, IRC mastercylinder, braided lines and race clip ons to fit, and all this before the bike gets picked up for monteblanco in Feb…..
  17. si1000repsol
    I get my Titanium from Pro-Bolt for the standard ones, Mettec for more specialised ones. The rest I get custom made.
  18. Clarkey
    Clarkey Member
    Just brought a set of limited edition shadow brake lines Can't wait to fit image.jpg
  19. arc76
    arc76 New Member
    looked at the pile plastic boxes she is in in my new shed before the work starts on her re build as i got my planer out for a lad to borrow at work this morning
  20. paulbusdriver
    paulbusdriver Active Member
    Just swapped Brembo mc 19x18 across from my trusty giver k2 onto the Blade whilst weather crap. This was to see if I could get rid of the spongy lever feeling with oem mc . Feels much much better, had fitted braided lines last week with no difference to oem mc but voilahappy chap. Will stick with this Brembo and see how it feels on the road . I have fitted Ebc track (not for road use)pads from hps with their 2 for 1 offer , noticeably more bite. I have not put the shims back on the pads but put a bit if copper grease on the back and then red grease on the pistons, this now all seems to greatly reduce brake drag and I now get 3 rotations and not 3/4 that I had previously from front wheel.
    Is this ok to do guys in the know?
    #2760 paulbusdriver, Dec 17, 2013
