paddock stands
Discussion in 'Maintenance' started by rocket, Oct 30, 2011.
  1. rocket
    rocket Active Member
    hi all, following my post regarding bike benches i need to find out widths of various stands. i have an abba stand so know the size of that but would be a great help if you guys who have normal paddock stands could measure the outside width of them ( where the roller/wheels are when on floor) the next time your in shed/garage etc. just keen to order up a bench but got to make sure i by the right one. thanks guys
  2. JD
    JD Active Member
    I'll be happy to do that tomorrow mate if noone has already done it for you.
    JD
  3. Simon
    Simon Active Member
    Hello mate, I have a Harris rear paddock stand and the width from outer wheel edge to outer wheel edge is 46cm hope this is of some use
  4. JD
    JD Active Member
    Same as mine, so job done!.
    JD
  5. rocket
    ok thanks lads but if anyone got other brands that could be handy too.
  6. Gums
    Gums Active Member
    will look later today rocket
  7. tanstair
    tanstair Active Member
  8. dan.1moore1
  9. dan.1moore1
    Oooof 359 euros with out the wheels . extra 60 bucks for the wheels so 420 euros and then im guessing they want shipping aswell
  10. CastrolCraig
    CastrolCraig Active Member
    I must be old school, headstock front stand & harris rear stand and i can do all work i need to.
    i dont trust ABBA or similar stands, CoG is just all wrong once in the air!
  11. Remal
    Just what I use mate. harris rear and Headstock front cracking combo
    I have the Abba but with the Headstock stand it does not lift the rear enough ;(
  12. stevebetts
    stevebetts Well-Known Member
    Why use a headstock stand with the ABBA Remal?
    I use a bottle jack to lift the front along with the ABBA stand.
  13. Remal
    Re read my post. I use the Harris stand and headstock stand. Not the abba stand any more as using it with the headstock stand result in it not lifting the rear enough
