watch this
Discussion in 'Mods, Upgrades, Accessories and Products' started by gringo, Dec 23, 2013.
  1. gringo
    gringo Active Member
  2. Carl
    Carl Well-Known Member
    I like that
  3. Freedom of choice
    Looks like a great stand, I have been looking at it myself, not cheap but well made. They do a kit for a Panigale but it means a 2p size half-moon cut in the fairing which I am not 100% sure I want to do.
  4. SimonRR
    SimonRR God Like
    Loves those, Will have to get one some day :)
  5. Slick
  6. Repsol Rob
    Repsol Rob Elite Member
    The Warrior, Bursig.......and my Envy (for sale) all work virtually identical.......what you don't see is the adapter which has to be fixed to frame (replaces one of the engine nuts)
    it does put a few people off sticking out a wee bit (not me)....... plus many of the makes mentioned have had a small amount of improvised improvement before giving 100% satisfaction (See Steve Betts modified adaptor plate for a example)....... haven't seen online demos of blade lifting (only pics).........
    I did see a similar lift which "Abba" have produced but it works in conjunction with their stand......... so no comparison with similar cost....... but it looked really goos at Bike show.......
  7. Repsol Rob
  8. Repsol Rob
    Demo......... looks like its all in one instead of using a abba stand.............im impressed
  9. BlackDevil
  10. Slick
    Impressive but them abba engineers do put a lot of trust on that rear bobbin!
  11. Tifa
    Tifa Active Member
    Here's mine...had it a few years, but don't use it much as I've now got a normal ramp.
    It works well enough, takes up no space, and is great for when you need to get both wheels off the ground with the suspension unloaded.
  12. Ritchierich
    Ritchierich Elite Member
    I already have one of these stands, takes a lot of setting up and an adapter has to be fitted to the top through bolt mount on the bike.~
    However I don't trust it, reason been that the first one I was sent the bottom mounting pin sheared and bike nearly smashed into wall. After fitting revised top mount can't get front wheel off floor without the rear been ten miles high. The one from Abba looks far more secure.
  13. PeterT
    PeterT Active Member
    Where can I get a can of the dogs Bollox stuff as in your picture???
  14. Tifa
    Tifa Active Member
    :lol:...you've got the eyesight of a sewer rat....the dogs bollocks stuff was some leftover fully synth group IV oil....I'd always get it confused with the semi....so i labeled it as 'dogs bollocks' :D
