Off to buy a torque wrench
Discussion in 'Mods, Upgrades, Accessories and Products' started by Yorkshire Tyke, Jan 4, 2014.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Hey guys bout time I used the proper tools and settings so off to buy a torque wrench, I've seen there are different tolerances:
    8-60nM, 60-300nM, 40-200 etc.
    which one best suits motorcycle work?
    thankssss!!
  2. graemewalker
    graemewalker Elite Member
    sixty more than enough for bikes halfords do a canny one unless u have snapon money same job 80 odd foot pounds on rear spindle nm what does that convert to
    #2 graemewalker, Jan 4, 2014
  3. Yorkshire Tyke
    So go for the halfords professional 8-60? 3/8"?
    Guessing I could do with a separate one for tightening spindle nut etc?
  4. graemewalker
    yes next size up for axle nut for your track use 120 i think roughly for nut
  5. Yorkshire Tyke
    Ok cheers graeme will just buy the smaller range one for now, at 75 notes they aint cheap!! Thanks for your assistance
  6. Ian E
    Ian E Active Member
  7. ShaunH101
    ShaunH101 New Member
    A good 3/8's will cover most needs on a bike! Although most 3/8 don't go high enough for axle nuts and the bigger fixings! But then you've got to think, some 1/2" won't go low enough for things like case bolts etc..
    So basically, at work I use my 3/8" way more than a 1/2"!
  8. sps170373
    I've got two halfords torque wrenches in 3/8 and 1/2 inch type I think they cover 10-60nm and 50-200nm off the top of my head, both been good for everything I've need them for! Good quality and good price IMO
  9. sinewave
  10. wedgiewolves#223
    wedgiewolves#223 God Like
    I have a snap on 6nm-150nm does all the jobs i need really [​IMG]
  11. Tifa
    Tifa Active Member
    Well, they're not expensive either....kinda middle range?
    My 3/8" halfrauds one started to play up after 11 years of serious abuse....took it back, (tongue in cheek, no receipt) and it was exchanged for a spangly new one on the spot...no quibbles even.
    I also have the 1/2" drive jobbie....and it's been spot on up to now.
    Just remember to zero them when you've finished and they should last forever.
    Also, whatever make you go for, I'd recommend a dial gauge over a vernier type as they are so much quicker and easier to set, with less chance of setting it incorrectly.
    That Snap-On above is a superb top end piece of kit, designed for professional use....my only gripe is the battery.
    If you leave battery function tools in a cold shed/garage for prolonged periods, it destroys the battery lifespan.
    I have 3 tools that rely on batteries, and it can be a pain in the arse pulling one out of the toolbox when you need it only to find the battery is fooked.
    For that reason, I always keep spare batteries in the house :)
    #11 Tifa, Jan 4, 2014
  12. wedgiewolves#223
    I have had this 6 months still on original battery/battery's I don't even know how many it's got ha ha I always have spare batteries lying about so not a big problem
  13. ShaunH101
    Same one as mine... But unless using it every day, not many people would be willing be fork out close to £300 for one :)
  14. Repsol Rob
    Repsol Rob Elite Member
    Jesus Shaun........looks like the Docs Sonic Screwdriver........................or are you a Jedi ?? :eek:
  15. sinewave
    That's just showin' off Wedgie & Shaun!
  16. ShaunH101
    My master said I'm not ready yet :(
  17. Repsol Rob
    Which Worcestershire bit you from Shaun in case I need to borrow one ?? ;)
  18. wedgiewolves#223
    Ha ha think mine was £215 done me a bit of a deal not too bad I do use it a lot at work though
  19. Tifa
    Tifa Active Member
    Yep, battery life is good. There's negligible current draw.
    Chances are your battery will be good for a few years before it goes AWOL.
    It's a good plan to keep a spare (or two) and don't forget to check yer battery compartment periodically for battery leakage.
  20. ShaunH101
    Droitwich mate, happy to help you if you ever need a hand! :)
