Front brake caliper seals gsxr1000k2
Discussion in 'Other Bikes' started by paulbusdriver, Jan 8, 2014.
  1. paulbusdriver
    paulbusdriver Active Member
    Help,
    How the hell do you know which way round the brake seals go in the calipers, I have stripped the brakes down on my trusty gsxr and know that the seals need to go in the correct way round but I don't know how to determine which is the right way, I have put one in and tried to feel for a lip but boy is it hard to know if you can feel the lip or not, as I have put the same seal in both way round to see if I could find any difference, but no!! Brakes in bits and off to beat head up against wall. (Still I managed to fit my blades new harris clutch lever in 5 minutes)
  2. Slick
    Dunno about the gsxrs but for the Blade the fluid seal goes in first (the fatter one) then the dust seal
  3. moab78
    moab78 Active Member
    Is one of the inner edges rounded/chamfered?
    If the seals are square cut, I don't see that orientation can make a difference.
    I did my calipers last year and could not see any difference. They seem to work.
