My 2006 CBR1000RR
Discussion in 'Mods, Upgrades, Accessories and Products' started by viper_biker, Jan 24, 2011.
  1. viper_biker
    viper_biker Active Member
    Bough in August 2008 and been slowly building it up with bits here and there. Mod list below,
    2006 CBR1000RR
    Zero Gravity screen
    Stock forks with Maxton internals
    EBC Pro-Lite discs
    PVM front wheel
    R+G fork protectors
    Moto-777 short black levers
    R+G bar ends
    Braided 2 lins brake hoses
    Braided clutch hose
    Carbon upper tank panel
    Carbon lower tank panel
    Harris quick release fuel cap
    R+G frame sliders
    Ex-BSB Micron Serpent system (the 62mm one)
    Gilles rearsets
    HRC rear brake reservoir
    Ohlins rear shock
    Carbon swing-arm protectors
    Carbon chain guard
    Carbon rear hugger
    R+G tail tidy
    PVM rear wheel
    Gilles chain adjusters
    Gilles lifters
    R+G paddock bobbins
    K+N filters
    PCIII with custom map
  2. viper_biker
    PVM's are off the bike currently and are going back to Germany for a re-spray and I fitted some Ohlins R+T forks yesterday. I'm going to change the braided hoses for HEL ones shortly as I don't like the current ones fitted. Other than that, I'm pretty much finished with the bike for now.
    I'll update the photo's once it's back to it's 'normal' self.
  3. CastrolCraig
    CastrolCraig Active Member
    LOVELY, re the ohlins, are they stock or uprated, as you might find them slightly worse than the modded ones you currently have!
  4. viper_biker
    At a guess, they'll be stock inners. They have just come back from PLR (Ireland's (North and South) sole importer for Ohline products) and I'll be bringing the bike to Phillip McCallen to get it set-up and see what he thinks (McCallen was a 4 time race winner at the IoM TT, so I hope he knows what he's at LOL)
  5. CastrolCraig
    big phil sure does know what he is doing. its quite surprising the comments about stock ohlins R&T forks though!
  6. viper_biker
    I know what you mean. A few have said about ditching the stock insides for superbike internals. A mate has John Burrow's (another road racer) forks in his K9 so I might see about getting a run on his and see how different they feel.
  7. viper_biker
    These y'ins
  8. viper_biker
    Got the latest bits today. I never fancied putting the standard black calipers on the gold forks and gold wheels so say hello to a set of brand new, never fitted, 2011 monoblocks from the Repsol Fireblade. I'm still waiting to get a carbon fender, a spacer for the forks and new bolts. I hope it's all going to go together for about April/May and I hope I've a new exhaust by then. The one I was looking at getting has gone :-(
  9. viper_biker
    Finally got the forks fitted. Still need to get the calipers fitted and new lines ordered. The wheels are still in Germany and not yet painted and still on the look-out for a new system. Nearly there,
  10. Rob
    Rob Administrator
    Holy Sh!t that looks amazing. How are the forks out of the box?
  11. viper_biker
    The only way I can descirbe them is 'plush'. Soak up the road bumps but react quick enough when you need them too. I've been told that the SBK internals are even better again, but I simply can't afford to put them into the bike (for now anyway) A mate has an 07 1000RR with the same forks and SBK internals so I might try and get a ride on his and see if it's worth the extra.
  12. viper_biker
    Finished for now,
  13. dan.1moore1
    Fwooooorrr........Nice Nice NICE !!!!!!!!!!!!!!!
  14. matt
    matt Active Member
    on the pic that you can see the sprocket what is the bracket for by the chain adjuster?
  15. JM1
    JM1 Active Member
    At the back? The lifter (for easy paddock stand usage)
  16. matt
    matt Active Member
    not the bobbins the one that is at the back of the swing arm, or is that a different type of bracket for different paddock stands
  17. viper_biker
    Got it in one, it's a Gilles paddock stand lifter, kinda similar to the factory lifters on kit swingarms.
  18. dan.1moore1
    I would like that paddock stand set up but they run at about 200 bucks dont they ?
  19. viper_biker
    New system time :D :D :D
  20. dan.1moore1
    Looks good mate.. What make is the exhaust ?
