Looks good, but just 2 points to mention: 1. I think you have fitted the rear one the wrong way round, you also don't need to hold the hose at the front of the swing arm, this clip can be removed. 2. Where you have fastened the two front hoses with 2No P clips (on the lower triple clamp), you will find when you brake, the braided hose is held and causes it to bend quite severely, I only used one P clip to hold the nearside calliper hose and took off the rubber surround and allowed the offside calliper hose to move freely. Hope this helps?
