go pro
Discussion in 'General 1000RR Discussion' started by racman, Jan 25, 2014.
  1. racman
    racman Active Member
    Keep it short and sweet guys. Which is the best go pro camera for trackdays and road riding
  2. ColinBR
    I'd say the new series of GoPro especially the black edition would be the best from GoPro.
    There are other makes out there though that others may prefer
  3. Andy
    Andy Active Member
    Tbh there is nothing wrong with the whole GP range, I have a gp3 black edition the quality is amazing.
    I have some screen capture images in my gallery if you want to have a look what the quality is like
    http://1000rr.co.uk/members/andy-albums570.htm
    #3 Andy, Jan 25, 2014
  4. Skippy79
    Skippy79 Active Member
    I've got the AEE S50, great camera, pretty much the same as the gopro 3, but a bit cheaper. Accessories for the gopro are better than the AEE camera!
  5. rob929rr
    rob929rr Active Member
    I have a gopro hd 1 (3 years old) which still gives amazing 1080p if needed. That is a testament to the quality. Buy the latest model would be my advice. It'll last years.
  6. Alblade
    Alblade God Like
    3+ Black edition is a superb unit - you only have to look at BBC / ITV productions and they are using them all over the place and quality is amazing from them.
    Takes a bit of time to get the best from the position of the mounts - you want the camera rock solid or any wobble is magnified 100 times on playback -
    There are quite a few on here who have produced really good films from trackdays and road riding with a variety of mounting locations
    The best bit about buying into the GoPro round is the huge amount of 3rd party mounts and devices which are now available via eBay etc. which supplement the official ones and are good value.
    of course the other option is to buy 2 or 3 second hand versions of the first HD ones for the price of a Black 3 and capture loads of footage - but depends what you will do with the results / how much spare time you have to edit etc. (and it takes AGES!)
    Couple of my films here :
    https://vimeo.com/84699152 - Chest mount on road in Spain
    https://vimeo.com/83210133 - Off road in pouring wet using chest mount plus some with it on a tripod
    https://vimeo.com/63916322 - Salford quays light show - mix of cameras but the low shots and panning are GoPro
    https://vimeo.com/53280363 - Time lapse over Manchester Albert Square
    https://vimeo.com/44171357 - Snetterton track day with forward and rear facing footage.
    https://vimeo.com/27099804 - Donny Trackday - camera mounted on side fairing quite low to catch front wheel
    Good mixture there of uses for GoPro - some road some track some using it attached to a Pot Noodle countdown time to give a timelapse pan unit
    All above shot with a GoPro HD 1
    #6 Alblade, Jan 25, 2014
  7. paulbusdriver
    paulbusdriver Active Member
    GoPro cameras are some of the best cameras out on the market. I have the original hd from several years ago and am looking at upgrading . Would suggest the silver as this is really is all you will need as the file size for the Black will take some serious number crunching from your computer = jerky video etc. trust me on my 50 inch pioneer plasma screens 720 is simply all you will need , looks fab
  8. Alblade
    Alblade God Like
    Agree - almost all the above I filmed in 720 - some folk go 60fps in 720 for smoother footage
  9. Ritchierich
    Ritchierich Elite Member
  10. jimglasgow
    jimglasgow Member
    I use the drift ghost which has a remote which i attached to my arm and built in screen, if you follow baron von grumble on you tube you can see his footage and he has 10% discount, i had a Go Pro prefer the Drift as it has some better features, including a lens adjustment. IMO
  11. sinewave
  12. Ritchierich
    Hi Jim, can you tell me what the "Lens Adjustment" does please?
  13. colly
    colly Active Member
    If you are buying a GoPro, get the 2 or 3, the 1 is a pain to use sometimes
  14. jimglasgow
    jimglasgow Member
    #14 jimglasgow, Jan 26, 2014
  15. sinewave
    The Lens adjustment is basically like a Spirit Level for the lens so as said if you can't mount the camera bang on vertical or 90 degrees to the vertical you can twist the lens so as the picture is recorded vertically.
