Short arses.....
Discussion in 'General 1000RR Discussion' started by DannyBhoy, Jan 27, 2014.
  1. DannyBhoy
    DannyBhoy New Member
    As a shorter man upgrading to my first blade imminently what I wanted to know is are there any fellow short lads around here and how do you find it day to day? Been out for a run on a blade but only for an hour or so.
    For reference purposes I'm 5'7 with a 29" inside leg.
  2. dave d
    dave d Elite Member
    youl be fine Dan its us taller chaps im 6"2 who struggle! legs ache after 20 mins.
  3. DannyBhoy
    I have read that loads of times, I know I can't get both feet flat on the Blade but I can deal with that I'm sure.
  4. SimonRR
    SimonRR God Like
    Yeah I agree with Dave, it's the only time I wish I was shorter :eek:
    trying to squeeze into a blade on track when your over 6' 1" is not so easy, hence I wont be going to a smaller cc track bike, like so many seem to do ;)
  5. megawatt
    megawatt Well-Known Member
    Same dimensions as you mate, but I manage. Not difficult to lower a blade either.
  6. DannyBhoy
    Have you lowered any of your previous bikes? Im on 600RR09 just now and manage just fine and the seat height is roughly the same as the blade. Just the width worried me a little.
    Its the SP I have on order so fully adjustable ohlins should play into my hands.
  7. sps170373
    M&p do a lowering kit for the blade, it's about £60
    But you'll also need to mod the side stand, I have seen a link for one and will try and find it
  8. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    The newer blades are among the smallest of the litre sports bikes. I'm 5'8 and 65kg and its perfect for me. The zx10 and rsv also seem a good fit but i wont disuade you from a blade you wont look back!!
  9. AshBlade
    AshBlade Riding Goddess
    Im 5ft 4in and have no problems with my Blade.. But i do own a pair of magic Daytona bike boots,a God send for short arses..:D
  10. navvy10
    navvy10 Well-Known Member
    I'm 6ft 2 with a 32" leg and not a single problem with the blade, not that that will help you mind.... ;)
  11. fez.57
    fez.57 Well-Known Member
    I would advise similar to ash. Just buy boots with a really thick bottom to help you out a little. Also eating a few pies will magically lower the seat closer to the ground
  12. Andy
    Andy Active Member
    I'm sure you will be ok, if Dani Pedrosa can ride one and his inside leg measurement is about 5" your going to be fine :D
  13. Kentblade
    Non issue matey, just need the correct riding kit
  14. Barstewardsquad
    About the same size as you and it isn't a problem. About the only time lanky gits have an advantage is when waddling the bike backwards.
  15. rewy..rr
    rewy..rr Active Member
    I am 5'5" with 30" inside leg. No real problems, expect when 'waddling' the bike backwards.
    A definate 'shortarse' in comparison with some of you.
    #15 rewy..rr, Jan 27, 2014
  16. AshBlade
    My Boots cost £320 so you will have to be a pretty determined short arse to justify spending that amount of money,(or have a wealthy husband) Bloody good boots tho...:cool:
  17. JimGreen
    JimGreen Active Member
    I'm not the tallest, with a 30in inside leg and I manage no problem and it's my first 1ltr bike.
  18. rob929rr
    rob929rr Active Member
    I'm 5'8' with 29" inside leg. I was a bit tip-toey on my 929 so fitted a lust racing 30mm lowering kit but also dropped the forks by 5mm. Been fine for 2 years now. I didn't shorten the sidestand and it hasn't been a problem for me although it does sit a little too vertical so I might sort that soon.
  19. bob
    bob Active Member
    im about the same height as you danny and i use mine to commute i the summer and its no problem!
  20. wurzel
    wurzel Active Member
    Im 5 foot 8 and have a 27 inch inside leg and I don't have any problems. I also have a large frontal area which may help me a bit.
