What air filters is everyone running
Discussion in 'Mods, Upgrades, Accessories and Products' started by Grant Hay, Jan 30, 2014.
  1. Grant Hay
    Grant Hay Active Member
    Hi, What's the best air filter to fit to a 2010 Blade ? or is the O.E filter just as free flowing ?
    I've seen people using BMC,K&N,Pipercross, but wasent sure what was the best.
    The only mods on the bike is a R-77 slip on ,Power commander 5 and a 02 Eliminator.
    Any opinions would be welcome.
    Grant
  2. Skippy79
    Skippy79 Active Member
    I've got a BMC, only because I had one on my 08 blade and was happy with it, so got another one for my 13 blade. Otherwise cut the clips off the metal sheet on the oem and remove the metal sheet, lets in more are, but still stops all the crap
  3. IcarusGreen
    IcarusGreen Elite Member
  4. Grant Hay
    Is it the Race or the normal variants that you guys are running ?
  5. martinowen
  6. alan68
    alan68 Active Member
    K&N just the normal one, got it from Demon Tweeks on here fitted it start of the week.
  7. restone
    restone Active Member
    K&N race as it compliments the exhaust Arrow full race system. The finer mesh and its increased airflow mean higher maintanence, the road version is a bit more robust.
    I've got and had K&N on all my bikes and cars even my diesel pickup trucks. They are so easy to maintain spray them with the cleaner, rinse off, dry and spray with the oil, the more oil they build up the more efficiently they work (untill gacked up with shite). If looked after they will last the vehicles lifetime and you can clean them as often as you like. The cleaning kit does umpteen cleans for £15 ish. Whats not to like?;)
  8. Skippy79
    bmc race is what I have
  9. Gilesy
    Gilesy Elite Member
    Recently changed to BMC race.. but haven't had it on the road yet.
  10. Mr_Spinalzo
    Mr_Spinalzo Active Member
  11. Slick
    bmc road
  12. Grant Hay
    Thanks for your input guys , ordered a K&N Race.
