Oil Filter Wrenches?
Discussion in 'Maintenance' started by sinewave, Jan 31, 2014.
  1. sinewave
  2. Muffking
  3. sps170373
    Depends if your using oem or aftermarket filters? if oem I'd get the honda oil filter remover, k&n has a nut on the end so easy to remove
  4. sinewave
    It's for my ZX10R Tracker if that makes a diff?
    The Blade just goes to the Dealers as it's not a year old yet and I'll probably swap it out before it's 3 years old.
  5. sps170373
    Go for a k&n filter as it comes with a nut type end simples!
  6. wedgiewolves#223
    wedgiewolves#223 God Like
    I have my honda one as I only took it at 580 miles and I'll do then myself now . It also fits my zx6r
    http://bit.ly/1eEalWp
  7. restone
    restone Active Member
    I ve always used the strap and cam universal type on oem filters. Its just a handle with a cam end and a flatened ring and a thick canvas strap. you wrap the strap around feed it thru the ring and the cam works against the filter body to tighten the strap and turn the filter. They can be used for tightening up too but be careful as they easily dent the filter. Only cost £8 ish from halfords.
  8. Scott
    Scott Active Member
    Large grips / water pump pliers . Best Iv used
  9. porcpen
    porcpen New Member
    I hammer a screwdriver into the end of the old filter to get it off and hand-tighten the new filter.
  10. fez.57
    fez.57 Well-Known Member
    I had to put a screw driver through the oem honda 1 as it wouldnt budge. K&N on now so no problems next time
