30mm SAG ???
Discussion in 'Maintenance' started by Blackness, Feb 1, 2014.
  1. Blackness
    Blackness Active Member
    Hello.
    Tomorrows job is setting the sag on my suspension before i start the finer tweaking (or i give up and go to Steve Jordans)!
    Ive got an RR6 and I've looked at lots of vids and posts and gone into information overload :/
    What does anyone, for once and for all, recommend i set my sag at please ??
    Cheers G
  2. lambchops
    lambchops Elite Member
  3. kev.b
    kev.b Well-Known Member
    Got this setup from ActiForce Racing at a trackday at Brand Gp Circuit . Works very well on my 06 blade .
    Forks
    Fork height 1mm
    Static static sag 27
    Comp LS 1
    Rebound LS 1.75
    Preload 15
    Standard Rear Sock
    Static sag 11
    Comp LS 3
    Rebound 4.25
    Preload Level 5
  4. Blackness
    Thank you lambchops. I have been browsing that and it is really good.
    How much do you weigh Kev ?
  5. sinewave
  6. kev.b
    Weight 13 stone without bike leathers , helmet an boots .
  7. Blackness
    Cheers dude but I'm about 3 stone heavier ! Its gonna be a learning curve :)
  8. sps170373
  9. Blackness
    Hello mate.
    Ive just got in from tinkering and seen your set up and mines worked out so different !
    I went with this page Motorcycle Suspension Setup ! Ive done everything as they said and they recommend: Rear Rider 30-40mm and static 5-10mm. Front rider 35-48 rider, and 25-30mm static ! I got mine to rear rider 36mm and static 6mm and front 48mm rider and 29mm static ! Had to preload rear shock to 10, the max setting and 1 turn of preload on the front :/ ! Haven't done anything with compression and rebound yet but it seemed to ride so much better !
    Its all voodoo ya know !!
  10. Slick
    Yep sag is the easy bit.
    It's the compression/rebound rates that you need a bit of experience to get right.
