Yoshimura r77 carbon exhaust for sale
Discussion in 'Parts, Accessories & Clothing' started by Bloy182, Feb 13, 2014.
  1. Andrewzzz
    Andrewzzz Active Member
    Wise choice man! I strongly recommend getting ignition module and quickshifter with it as well! After fitting that set to my cb1000r I don't know why and how I could live without that! Quickshifter rox! Launch control is awesome! :D Flames from PAIR system....mmmmmmmmmmm!!! :D
  2. Bloy182
    Bloy182 Active Member
    Ignition module? What does that do? Do you require a Power Commander to install a quick shifter?
    I could get a PC 3 but can you download the maps from the site into that one?
  3. Andrewzzz
    With ignition module u can do few things, set launch control, retard/advance ignition timing, raise rev limit. You need to map it on the dyno as it would be really silly to use someone else's map and kill your engine. :) Go for PC5!
    My bike got 10HP power increase from ignition module map.
