Wise choice man! I strongly recommend getting ignition module and quickshifter with it as well! After fitting that set to my cb1000r I don't know why and how I could live without that! Quickshifter rox! Launch control is awesome! Flames from PAIR system....mmmmmmmmmmm!!!
Ignition module? What does that do? Do you require a Power Commander to install a quick shifter? I could get a PC 3 but can you download the maps from the site into that one?
With ignition module u can do few things, set launch control, retard/advance ignition timing, raise rev limit. You need to map it on the dyno as it would be really silly to use someone else's map and kill your engine. Go for PC5! My bike got 10HP power increase from ignition module map.
