  1. Gilesy
    Gilesy Elite Member
    Well after putting my exhaust back together after gutting the cat (See here), the postman turned up with a little bling for me :D
  2. Barstewardsquad
    Got the mobile tyre fitter coming tomorrow so took it off the abba stands, hit the button and started it. Has been on a solar charger since before the clocks changed and it still fired at the first press, gotta love Hondas.
  3. Bloy182
    Bloy182 Active Member
    Those pictures are impressive, what camera do you use?
  4. MrB
    MrB God Like
    Thanks, it's an old Nikon D80 with a 18-135mm kit lens.
  5. JimGreen
    JimGreen Active Member
    I was going to ask exactly the same question.
    Great Photos.
  6. derchef
    derchef Well-Known Member
    yep great pictures!!!
  7. el-nicko
    el-nicko Well-Known Member
  8. Black
    Black Active Member
    Fitted new mirror and tidied up the minor damage from a door falling on it and pressed the button. Been sitting since 2nd September last year with no charger on it and it started first time. Happy days!
  9. Gilesy
    Gilesy Elite Member
  10. derchef
    buyed new metz for my sc57 , after discovered than run a 180-55 instead of a 190-50 give the chance to lost one (Fucking) point of driving license in this damn country
  11. Barstewardsquad
    Had my S20s fitted along with new chain, sprockets, wheel and sprocket carrier bearings. Took the rear cowl off to sort the back electrics out and to fit my Nano indicators only to find out that I need some blooming adaptor to fir micro indicators to my R&G tail tidy. May have to improvise something with some large washers for now.
  12. johnd
    johnd Active Member
    Learnt how to remove the side panels and fitted an R&G radiator guard. I hate those rivet clips with a passion.
    #2972 johnd, Feb 21, 2014
  13. JimGreen
    I've just put S20's on, not really had chance to give them a good run yet though. Let me know how they compare to whatever you had on before.
  14. scooboo81
    scooboo81 Member
    Fitted my new chain adjusters and r&g radiator guard.
  15. johnd
    johnd Active Member
    Managed to finally fit my xmas presents too.
  16. Barstewardsquad
    Bt16 pros before. Was hoping to get out this weekend buy it is looking increasingly unlikely :(
  17. Clarkey
    Clarkey Member
    Took the bike out image.jpg for a run today to test the new Gilles rearsets awesome I love riding my blade
  18. Barstewardsquad
    Did my home made adaptors for the nano indicators onto my r&g tail tidy. Stuck a 10mm and 12mm washer together then gave them a quick rattle can black gloss finish. Did four of them and hopefully they will be dry enough to fit tomorrow.
    Also replaced the indicator relay with an LED compatible one and removed the inline resistors from the front indicators whilst the fairings were off.
    Tomorrow will hopefully put it all back together and fit my new rear fairing cowl so I can have a pillion seat to take the missus out on rides. May need a new seat cowl though, but that is a seperate story.
  19. Bloy182
    how do you remove the top part of the side panel? it seems tightly fixed into the air duct section??
  20. johnd
    johnd Active Member
    What year blade is yours? Mines an 06, if the avatar pic is yours I think yours is a newer model. Otherwise there are push/screw rivets lurking everywhere.
