  1. Bloy182
    Bloy182 Active Member
    Yes push screw rivet model lol
  2. el-nicko
    el-nicko Well-Known Member
  3. Haggler ®™
    Haggler ®™ Active Member
    Started to strip engine .................Gear clusters out, cases split and removed the Balance shaft. Cush drive rubbers OK............ bugger!!!!!!!, Oh well.........I,ll be bolting it back together this week and bunging in a set of plugs aswell as checking the clearences.
  4. Alblade
    Alblade God Like
    Started to give it a full on clean - all plastics removed
    Rad soaking in warm water - Its not pretty but its not been done in 80,000 miles and if you only knew what it has been ridden through.
    In last 3 / 4 months it's had:
    New chain and sprockets
    New Headstock bearings
    New wheel bearings front and rear
    Air filter cleaned yesterday, oil and filter will be changed this coming weekend
    New brake pads front and rear
    New tyres
    Coolant will be replaced when rad goes back on.
    Plugs were changed about 10k ago so good for another 20k
  5. derchef
    derchef Well-Known Member
    tail , turn signal , and fucking rele
  6. SimonRR
    SimonRR God Like
    Took my forks off, they had a full service, new seals, re shim, new oil, racetech compression valves and springs to suit my weight, just put them back on :)
    now just got to find time for the full 16k service and smaller front sprocket, must hurry, spring is only a few weeks away
    I know what my next days off will be assigned to ;)
  7. Bart
    Bart Active Member
    Took my old Blade for it's MOT and it passed again, over 60K on the clock now and sporting some Chinese discs, will have to see how they fare.
  8. drewl999
    drewl999 Active Member
    Took my blade for its first MOT (3 years old 1st march) and it FAILED due to exhaust noise. Massively annoying. Its a Leo Vince GP Pro and it had the db killer in. Now fallen out with my local Honda dealer.
  9. derchef
    replace tire on 2004 with new metz m5 120-190/55
  10. Haggler ®™
    Road test of about 50 miles since refitting the engine after "Open Heart Surgery"...............alls good , no leaks , ..............now praying for some sun.
  11. foenix
    foenix Active Member
    Just received my metzeler M7 RR, mount my new motodynamic tail light and depose my engine for some boost ....
  12. Wozza
    Wozza Elite Member
    Went out in sunshine and thought this is spring,then got caught in hail shower so 2 hrs of cleaning followed:eek:
  13. Alblade
    Alblade God Like
    Spent a while cleaning up the front of the engine and round the spark plugs / connectors to remove all the road grime and junk
    Put the air collector box and air tube gaskets back on
    Cleaned R&G guard up which needs a light sand prior to a spray with satin black
    Next is to prep the sides of the radiator for a coat of paint - may get the polishing buff out and apply some to the downpipes before the rad goes back on over the weekend
    Need to cut out the long dead Datatool 'Snitcher' which was hard wired in - switched 12v socket also removed.
  14. rodders4legs
    rodders4legs New Member
    Ordered myself a glpro gear indicator and MRA double bubble screen now to wait for them to arrive :)
  15. Barstewardsquad
    Fitted the Oxford Nanos to the back after improvising and spraying some washers to fit them to the R&G Tail Tidy. Must say I am not impressed with R&G, emailed them last weekend about the proper bits and have heard f@#k all back from them. Won't be buying any more of their kit if that is their attitude.
  16. rb1000rr
    rb1000rr Active Member
    Totally agree about the R&G mate i had one on my RR6 ended up selling and buying an Evotech instead much better looking build quality i fitted Nano s a year or so ago to it too with no grief at all maybe worth a thought
  17. travellingkiwi
    travellingkiwi Active Member
    Rode in driving rain to town... Then treated the bike to an 8000mile service, new front tyre (PR3) and front brake pads... They even gave it a wash...
    Driving rain again home... Boy is is wet... Thought I might have to get off and swim on the M4 at times...
    H
  18. Jap_STi_3
    Jap_STi_3 Member
    Glad to report I've been out and about at last, now i can walk upright again! (Long story)
    Had a ride over to Compo's Chippy Thursday night with my mate LBK for a chippy tea.
    Then yesterday I visited Blackpool Honda, great bogs by the way! Then back via as many back roads as i could find to Preston Harley Davidson for a mooch round some Big Shiny Bikes
    Then back to the Wine Press for a brew before home
    I just love watching the sun go down after a cracking day in the saddle.
  19. scooboo81
    scooboo81 Member
  20. Gilesy
    Gilesy Elite Member
    Talon sprocket..
