FGRT204 or FGRT813?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Andrewzzz, Feb 20, 2014.
  1. Andrewzzz
    Andrewzzz Active Member
    I can fit K-Tech, and I will probably do that till I have everything required to fit FGRT204 to my bike. You are second person who tells me that Ohlins is made for silky smooth tracks and not the road....
  2. Iain
    Iain Active Member
    I had Ohlin's front and rear on my 04 blade, only every used it on the road, it made a huge difference, it just went wherever it was pointed and ignored any bumps on the road. It does depend on how they are set up I guess, as the ones on my Factory Tuono were a lot harder than the ones on my blade. Fitting forks to the CB though could be a bit trickier as you will need to get where to fit them in the yolks in the right place, too high and it won't turn in, too low and it will turn too quickly - but if the overall length is the same, you should be near enough.
  3. Andrewzzz
    Overal length is less on the Ohlins, they are 20mm shorter than cb forks. I guess I need to get the rest of the bits I need for this and check how it will behave before I spend £2k on Ohlins forks.
  4. Iain
    Iain Active Member
    20mm seems too much to me, unless you can try before you buy the you may be better going down the kais/mct/k-tech route.
  5. Andrewzzz
    Thats why I'm testing this on stock fireblade forks and not on Ohlins ;)
  6. Jamiestrada
    I'll will let you know what the 204's are like on the road as soon as I get out on the bike again ;)
  7. si1000repsol
    I have the 813's and love them. They have transformed the handling but then again I have never tried the 204's
    #27 si1000repsol, Mar 4, 2014
  8. Jamiestrada
    At least the Brembo M4s fit yours Si :(
