Magnetic Sump Drain Plugs
Discussion in 'Maintenance' started by Barstewardsquad, Mar 1, 2014.
  1. Barstewardsquad
  2. arthurbikemad
    As discussed earlier about sump plug corrosion you have to think anything that deviates from the norm could make the situation worse, most of the mag sump plugs use a lot less thread and for that reason I leave them alone, another option (never proven to how well it works) is to attach a high power neodymium magnet to the filter in theory it will collect any partials and hold them in the filter, once done it fan be moved to the new filter and partials will be disposed of. You could drill a normal one and mount a neo mag to it with some resin. Check the depth first.
  3. Barstewardsquad
    Cheers Arthur, Just read the post you mentioned, will take your esteemed advice and stay OEM.
  4. Mike07
    Mike07 Active Member
    Firstly I have no empirical (looked that up) evidence or knowledge on the subject. But the arguments I can think up are;
    If you are picking up metal shavings, it's too late
    If the shavings are so small the filter isn't collecting them, why worry.
    Regular oil changes should be enough.
    On the other hand.
    What harm can it do.
    It will stop your oil turning to grinding paste.
    You are just helping the filter out.
    It's interesting, I think I may get one of the powerful magnets.
    Mike.
  5. arthurbikemad
    does work the magnet on the filter trick, but like you say, if they get that far surly the filters doing its job anyway?
  6. GappySmeg
    GappySmeg Well-Known Member
    Yep, I always do...... however, I cannot actually find anywhere that sells the genuine "plug and washer" kit for the 2007 blade... don't want to go to the local Honda dealer as its a pain, can anyone point me in the direction of a good supplier for the OEM plug & washer?
  7. BlackDevil
  8. Barstewardsquad
    Could post links later to the pages I have saved for Lings and David Silvers. They don't do them as a kit though.
  9. Barstewardsquad
  10. GappySmeg
    Nice one, thanks matey
