please help
Discussion in 'Maintenance' started by karloss200, Mar 6, 2014.
  1. karloss200
    karloss200 New Member
    Please help me rumble when the engine is cold advice please
  2. karloss200
  3. Bloy182
    Bloy182 Active Member
    sounds like the CCT, get it checked by your local mechanic tho
  4. martinowen
    Doesn't CCT go away when you rev and come back on deceleration?
    Hard to tel on vid but mine sounded similar but louder when I had parts of my gearbox rattling around in there :-S
  5. daz1
    daz1 Active Member
    i have a very sim prob
  6. karloss200
    After heating stops and go completely at ease
  7. daz1
    daz1 Active Member
    do you mean when engine warms up the noise goes away i have the same noise but only from cold when the choke kicks in once the chock goes off the noise goes away
  8. karloss200
    exactly as it is heated to 70 degrees noise disappears
  9. karloss200
    My English is not good to apologize
  10. Haggler ®™
    Haggler ®™ Active Member
    Dito................mine sounds exactly the same until 60 deg. It's worse if I use fully syn oil so I now use semi which made a hell of a difference. I have recently stripped the engine and found sweet f all wrong with it.
  11. karloss200
    I have a fix?
  12. Haggler ®™
    Which is??????????????????, pray tell.:rolleyes:
  13. karloss200
    what can I fix
  14. Barstewardsquad
    Does it go away if you pull the clutch in?
  15. karloss200
    No
