Where to buy coolant/anti-freeze in Lincoln
Discussion in 'Maintenance' started by Barstewardsquad, Mar 6, 2014.
  1. Barstewardsquad
    Just realised that I only have 2 litres of coolant and the bike needs over 3 litres so my plans to flush it all out this weekend are in danger of failing and stopping me putting it all back together. Does anyone know any shops in Lincoln that would have coolant in stock? Always used to use HG for stuff like that, and it's too late to order from DT or Opie Oils.
    Also realised that the coolant I have is nearly 4 years old, but as it is sealed I guess it would still be OK.
    Would have put this in the Lincoln group but the tumbleweed has made it all dusty in there ;)
  2. dessp2
    dessp2 Well-Known Member
    Try RWH they are top lads in there and reasonably priced.
    Or speak to Terry in Italia Motorcycles (wish we had a Honda dealers in Lincoln as good as them!! Saying that wish we had a Honda dealers full stop).
    Or Pete in B & B Suzuki
  3. blade1980
    blade1980 Active Member
    Would thought most if the bike dealers would, B and B , webbs , Italia etc, not sure if halfords would do it too
  4. Barstewardsquad
    Cheers folks. I did check Webb's website but it don't mention such stuff and Halfrauds only seem to have Car coolant. Will have a ring around the stealers and RWH, would expect the dealers to charge too much though.
  5. SpeedoX
    SpeedoX Active Member
    Got a fantastic service from Italia Motorcycles myself...
  6. Kentblade
    Mate, Halfords standard 2 year coolant is not just car antifreeze, it is suitable for motorcycle engines too. Just make sure it meets the spec in your owners handbook. Ethylene Glycol based. Do not use the VW spec G coolants.
    As far as the age of your coolant, it does not lose its properties to protect against freezing, unless you add more water and dilute it, but its ability to stop corrosion deteriorates over time, that's why you change it
  7. Muffking
  8. Barstewardsquad
    Managed to have a POETS day and popped into Global Bikes. Very helpful and as they only had 1 liter containers they gave me a bit of a discount. Job On :)
  9. Tim
    Tim Member
    Roger Marshall's son works at global bike. Would always use B and B myself.
  10. Barstewardsquad
    Who is/was Roger Marshall?
    Edit: Now know who he is thanks to Google.
    #10 Barstewardsquad, Mar 7, 2014
  11. moab78
    moab78 Active Member
    I've used comma xstream G30 for the last couple of changes that I've done. But after my last change I was looking for something else at ECP and spotted this:
    TRIPLE QX Red Ready Mixed Antifreeze/Coolant - 5ltr
    It seems to meet the same specs and with ECP you can collect or they deliver free - so would work out a lot cheaper than the comma.
