cleaning tip .
Discussion in 'General 1000RR Discussion' started by keithg1748, Mar 7, 2014.
  1. keithg1748
    keithg1748 Active Member
    hi just got my 2013 blade out of hibernation and the black frame , bottom of forks basically everything that's black has white deposits on could be mould ? , a barsteward to get off any ideas to clean off. bit disappointed with the cheap finish from Honda.
  2. bob
    bob Active Member
    Sdoc 100 did a good job on mine!
  3. Wozza
    Wozza Elite Member
    Hi Castrol bike Polish is good stuff and will also bring up shine .:cool:
  4. keithg1748
    thanks bob , i use autoglym conditioner great on the paintwork but wont shift it , but with it being a matt black engine etc it looks crap , i think ill give sdoc100 a go .
  5. Slick
    once cleaned off silicon spray brings it all back to show room condition
  6. Mike07
    Mike07 Active Member
    Wd40.
  7. keithg1748
    which silicone spray do you use. thanks
  8. Slick
    have used Silkolene but my current fav is WD Silicone spray - it smells just soo good!!
  9. RichC
    RichC Active Member
    Try a car detailing all purpose cleaner be sure to dilute accordingly and agitate with a brush
  10. Ritchierich
    Ritchierich Elite Member
    Wash with Sdoc 100 then apply ACF-50, worked for me.
  11. Plake
    Plake Active Member
    Keith are you near the sea by any chance?
    One of my old Hondas did this in my garage near the sea and I think it was early corrosion. With my 2012 blade I rub acf50 over everything apart from the discs with a rag and it keeps it from happening.
  12. Beckers
    Beckers Elite Member
    Dont think its cheap finish mate, more likely you didn't prepare it for a lay off..........
  13. Barstewardsquad
    I have the white spots, my fault for not cleaning her before winter :( Sure they will disappear with bit of TLC though.
  14. AABIKER
    AABIKER Member
    Could try muc-off degreaser
