Tips on putting left grip on ?
Discussion in 'General 1000RR Discussion' started by rollsroyce, Mar 12, 2014.
  1. rollsroyce
    rollsroyce Member
    Yeah i know easy peasy, well i got the throttle side on ok, but have had shit loads of probs with the l/h side, (i did post on this) well i got some proper glue and still the grip was turning, i had a spare grip, got the new one halfway on and would it budge, would it fck, so i cut a barsteward off, so today 2 new grips arrived, so any tips. i cleaned the bar up before, i am getting the jitters now,how about soap and water ?? (was told not to) only i dont want the same to happen again, cheers Rolls.
  2. BikersDiscountStore
    BikersDiscountStore Active Member
    Get it to an air line, stick air line between grip & bar, fire air line & push grip on. Simples.
  3. Barstewardsquad
    Hairspray. Will lube to start with and then will go tacky and hold it firm.
  4. Si.
  5. ahmedf
    ahmedf Active Member
    Either the airline as mentioned above or brake cleaner works well too. The fact the brake cleaner evaporates = less mess but provides enough lubrication to slide it on. If it dries up in the mean time just spray some more in.
  6. rollsroyce
    rollsroyce Member
    yep like the hairspray and brake cleaner, i have got both (poser) well i have still got hair and proud of it, but the old grey cover up comes in handy, thanks, guys will do 2morrow
  7. SIDEWAYS
    SIDEWAYS Senior Member
    As a cycle shop we use easystart to burn the grips on.Lubes to start with then burnsthe inside rubber to the bar.
  8. Great Guy
    Great Guy Well-Known Member
    Go on You Tube, there are demonstrations on there.
  9. rollsroyce
    rollsroyce Member
    better replies on here,
  10. restone
    restone Active Member
    hairspray. always used it on all my bikes motor and MTB. spray on the bar keep grip cool and out of sun (stops it buckling) tap home with rubber hammer
  11. Scott
    Scott Active Member
    Brake cleaner only for me
  12. wurz
    wurz New Member
    Chain lube does the job mate
