RR7 fitting Radiator/Fairing plastics
Discussion in 'Maintenance' started by Barstewardsquad, Mar 14, 2014.
  1. Barstewardsquad
    Am putting my RR7 back together and the plastic shroud that goes by the radiator to the fairings is being an absolute biatch. Just can't get one side fitted at the top under the nose cone as the holes won't line up.
    Does anyone know any tricks or the best way to fit this bit as I am at my wits end as it normally goes on fine?
  2. rb1000rr
    rb1000rr Active Member
    Hi mate do you mean the infill that goes down each side of the rad and join at the bottom to the centre piece of the bellypan or where the mid sections fiix under the nose cone
  3. Barstewardsquad
    The mid section that fits under the nose cone. Think it's part 3 here
    mainly where it connects with part 6
  4. 3056tat
    3056tat Active Member
    Hi mate,had my rr7 to bits today for the first time to fit a rad guard.
    I fitted new well nuts to the top mounts and left things loosish while i got things fitted.Everything seemed to line up ok.
    Maybe its time to leave it for a while and then go back.It"ll probably fly back together.
  5. Barstewardsquad
    That's what I'm thinking. Was running out of plastic clips/screws so binned in.
    Will leave it until tomorrow, bloody annoying though as was just 2 clips away from being done.
  6. Barstewardsquad
    Well better light and a clear head meant it all went back together nice and easily :)
  7. rb1000rr
    Glad you got it sorted know what you mean when the old red mist starts to rise deffo sound advice to leave it and go back
