low strength adhesive
Discussion in 'Maintenance' started by fez.57, Mar 17, 2014.
  1. fez.57
    fez.57 Well-Known Member
    My motograffix front number board has started to peel off slightly at 1 corner. What is the best adhesive to use to stick it back down, obviously I dont want anything too strong just incase I ever want to remove it
  2. ShinySideUp
    ShinySideUp Elite Member
    Not sure what off the shelf glue would allow same removal at a later date n not cause any damage.
    but you could use a little strip of venture shield or similar to stick the board down, its see thru so should be almost invisible and it can be easily removed without damaging paintwork.
    Well as long as a hot air gun is used. :D
  3. Slick
    clear silicone ?
  4. ShinySideUp
    silicone might not stick too well to the smooth plastic finish on the bikes panels, also it may peel during first wash as the mitt wipes over the area.
  5. The.kickboxer
    The.kickboxer Active Member
    Evo stick, it drys as a rubbery compound which has a dissolving agent available
  6. martinowen
    Bluetac
  7. fez.57
    Thanks martin, either that or double sided sticky tape lol
