fireblade 2005 pops 4th gear
Discussion in 'Maintenance' started by adamos, Mar 21, 2014.
  1. adamos
    adamos Active Member
    My blade pops 4th gear :( Any one know what need to do plsssss
  2. Barstewardsquad
    Check Chain tension.
  3. Mad Matt
    What do you mean "pops"??
  4. adamos
    jumps
  5. martinowen
    As I learnt this time last year the 04-07's have a cassette gearbox which just slides out of the side of the engine (so no need to split) my 4th gear broke 2 teeth off so I would check before something similar happens
  6. daz1
    daz1 Active Member
    hi have the same problem but only in 6 gear the gearbox is sweet going throu all the gears up untill you go over about 80/90 mph then it will feel like the chain as jumped the sprocket for a split second but only in 6 gear then its fine. got a 04 gearbox comming so will get it swopped over
  7. adamos
    Have to change gear box or only 4 gear?.
  8. daz1
    daz1 Active Member
    you can prob get away with changing just the 4 gear but you wont no untill you pull the box out and see
  9. martinowen
    Shame it's 4th that's gone as I have my old box which is all good but 4th
  10. Skippy79
    Skippy79 Active Member
    maybe Daz will have a 4th gear over after he is finsihed, would work out cheaper for both of you ;)
  11. adamos
    That's fantastic idea.I hope make deal with Daz
  12. daz1
    daz1 Active Member
    sadly have been out bid so i may just get it checked and repaired
  13. daz1
    daz1 Active Member
    well what a result i won the gearbox £122+20 pastage so adamos you may be lucky
  14. martinowen
    Bargain that mate, it cost me 250 + 20 post for my replacement.
  15. daz1
    daz1 Active Member
    thanks martin just lucky i guess lol
  16. adamos
    when you ready let me know :)
  17. Skippy79
    great this forum, helping each other ;)
  18. daz1
    daz1 Active Member
    ok mate will do
  19. daz1
    daz1 Active Member
    hi mate if you are in a rush the guy i got the gearbox off is selling parts of one you may be able to get the 4 gear of him cheap enough HONDA CBR1000 RR4/5 GEARBOX PARTS | eBay
  20. adamos
    hi anyone know the gear box 06 - 07 it's same what 04-05 ?
