Chain Lube
Discussion in 'Maintenance' started by jimglasgow, Apr 14, 2014.
  1. jimglasgow
    jimglasgow Member
    Folks,
    Going a wee trip abroad shortly and I'm looking for some advice on a quality wet chain lube (spray can) to carry with me any1 recommend anything. Dont like the dry stuff always feels nothing is on the chain
    thanks
    Jim
  2. raphael
    think most on here use wurth dry lube but a few use Castrol racing with no bother, I hav been using muc off through the winter with no bother and very little fling
  3. thezipsteruk
    thezipsteruk Elite Member
    I have swapped to worth dry chain.
    But prior to that I used the Castrol chain wax, one of the better ones for cling and fling lol
  4. bandit_287
    bandit_287 Active Member
    Wurth dry lube is the best I've used. Zero fling. A quick spray every 200miles or so and a clean and re-lube every 600miles ish.
  5. Remal
  6. AABIKER
    AABIKER Member
    Have been using Motul chain cleaner & lube & seems pretty good.
  7. rich918
    rich918 New Member
    Castrol for me
  8. Ritchierich
    Ritchierich Elite Member
  9. Ritchierich
    Day two and now 150 miles covered, chain still nicely lubed and rear wheel still clean, Sdoc 100 differently does what it says on the tin, highly recommended.
  10. Kentblade
    My own tuppenceworth.
    If you ride year round in all conditions, then in my experience the dry lube just does not cut it.
    Have been using the Castrol for a few years and seen very good results, just done chain and sprockets today after 21k miles mostly in harsh commuting conditions, never seen anywhere near that life with dry lube.
  11. Ratser
    Ratser Well-Known Member
    Been castrol racing for me since I first bought it at the TT two years ago.
  12. jimglasgow
    jimglasgow Member
    Owen, is it a spray, need it for touring in the bag
  13. Ratser
    Yes it is Jim.
  14. TheRamJam
    TheRamJam Well-Known Member
    sDoc100 Chain lube for me. Works brilliant. Comes in a tiny can to keep under the seat and can be refilled from the bigger 300ml can.
  15. AABIKER
    AABIKER Member
    Like the sound of SDOC100 - will give that a try
  16. sinewave
    Yes the SDOC is the way forward for Touring mode.
    It's the only small can that can be refilled from it's bigger 300ml brother.
  17. Clarkey
    Clarkey Member
    Just ordered some white chain spray on your recommendation so hope it's good been using wurth for last few years so will give it a go
  18. Ritchierich
    You won't be disappointed Clarkey, 4 days now and some 350 miles covered, back wheel still gold colour :)
    Best to put on chain night before and spray on inside edge of chain, top tip and free to you for choosing sDoc100 lube ;-)
  19. Ritchierich
    Well guys another update on sDoc100, did track day yesterday, chain still lubed and rear wheel nice and clean. Big thumbs up to the Germans who invented it.
  20. Vojtek
    Vojtek New Member
    Motrax is quite good
