Power Commander Setup - Help
Discussion in 'General 1000RR Discussion' started by RepsolSam, May 1, 2014.
  1. RepsolSam
    RepsolSam Well-Known Member
    Hi Guys,
    Have installed a PC into my RR9 - finding the bike is running little rough..enough for me to notice the difference.
    I have a Leo Vice SBK Can and a BMC Air Filter.
    Any recommendations on what map i should try?
    Any other settings you think i should check \ change? (fuel adjustments, throttle response etc...?)
    Also the PC has a 2 position map switching - what is this?
    Are there any extra's that can go with the PC V? as i have only used PCIII before?
  2. Barstewardsquad
    Only bit I can help with is the 2 position map switch. The PC5 can hold 2 maps and the switch lets you choose which one to use, i.e. a map with no baffle in and another with baffle in.
    I have been looking for new maps and there are quite a few on the powercommander/dynojet websites.
  3. ChrisOzzz
    ChrisOzzz Active Member
    Hi Repsol01
    Do you know what map you have installed on the PCV? You need to download a map to match the year exhaust and air filter type for you bike (or as close as you can find). Or find somewhere to have it mapped really the best option.
    Unless you really know what your doing DO NOT go fiddling with the fuel settings it could end in tears...
    The 2 map positions are to allow for eg: a baffel/noise killer in map & out map. You can switch between the maps by using a jumper wire in the correct socket or install a switch.
    you can get an auto tune box for the PCV which essentially maps the bike for you without taking it to a dyno, doesn't do as good of a job though, and you'll need to fit a wide band 02 sensor to make it work
    Ozz
  4. RepsolSam
    thanks guys..
    found maps here: Welcome to Power Commander Motorcycle Fuel Injection Tuning Module
    Have been told to only use the maps starting with 5 (last 3 digits)
    unsure what is on there..
    Would a different map be good for when the baffle is in and out? this could have been the reason it is like it is?
    I cant remember it may have been the throttle response that i changed on my old bike..with the PCIII
  5. RepsolSam
    SO there are 2 maps:
    16-002-503 - Leo Vince, air filter, Dynojet O2 Eliminator
    16-002-504 - Leo Vince with baffle , air filter, Dynojet O2 Eliminator
    So i guess i need these 2?
    So the question is what i use the first one with the baffle? and what is a Dynojet O2 Eliminator?
    W
  6. Barstewardsquad
    The o2 Eliminator is used if you don't have an o2 (lamda?) sensor in the exhaust.
    Those 2 maps look a good starting place.
  7. RepsolSam
    Okay..so am i looking for something that attaches to the rear can? will it be visible?
  8. RepsolSam
    Dynojet O2 Sensor Eliminator
    On bikes that use an O2 sensor in the stock exhaust have a closed loop area that can not be adjusted by the Power Commander alone. If you make adjustments with the PCIII in the closed loop area the O2 sensor will sense these changes and the ECM will alter the fuel curve accordingly. If you want to have full fuel control over the entire RPM range of your bike then you will need to bypass the closed loop area which the O2 eliminators will accomplish. If you are looking for the best fuel economy and not worried about making changed to the closed loop area you can leave the stock O2 sensors connected and still make changes outside of the closed loop area with the PCIII.
    so do i need to get this regardless? how would i know if one is already fitted?
  9. rosier1uk
    rosier1uk Active Member
    Hi repsol 01 I've not long fitted my pc5 to my 09 blade was told you have to have the 02 sensor eliminator fitted as the ecu will be trying to override the power commander. Really easy to fit as well
  10. RepsolSam
  11. CBR-Pete
    CBR-Pete Active Member
    Yes that's it, however it plugs into the loom where the O2 sensor came out just behind left hand side of engine just below the No1 injector plug if i remember right..not where you plug gear indicator in.
  12. rosier1uk
    What cbr Pete said and just tie rap old sensor plug out of the way behind the fairing
  13. RepsolSam
    My brother said he put a PCIII in...I thought the 09 needed a PC V?
    Would I still need the sensor with III
  14. rosier1uk
    Am 99% sure you will still need the o2 sensor eliminator with the pc3 and you can get a pc3 for the 09 blade. My mate just fitted a pc3 to his 09 gixer 1000 and he still needed the sensor illuminator
  15. RepsolSam
    checked it is a PCIII - my brother says that is all he installed..
    there maybe a eliminator installed but he is not sure..anyone got a pic of were i can find this?
    i have checked the correct map is on the PC - i have enabled the accelerated fuel pump and increased the throttle response - cant wait to try... made a monster of a difference in my on RR5
  16. el-nicko
    el-nicko Well-Known Member
    Here's a couple of pic's from when I recently fitted a PC5 To my '11 'blade. It's an ABS equipped bike so the plug may be in a different location on a non-ABS bike.
    dynojet_o2_eliminator
    #16 el-nicko, May 1, 2014
  17. steampig
    steampig New Member
    Thats it.... shoe horned into lhs rear between engine and frame
  18. RepsolSam
    That's under the seat right? So I shouldn't need to remove the tank cover \ tank
  19. steampig
    steampig New Member
    No its under the tank
  20. RepsolSam
    thanks for the picture..
    will try to open up the bike this evening..
    What would happen if this is not installed? and a PC is? would the bike ride any different?
    Am i thinking correct - the standard can has a o2 sensor - this gets removed when the rear can is changed...?
