Luggage Bags
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolSam, May 9, 2014.
  1. RepsolSam
    RepsolSam Well-Known Member
    Heading out to europe in a few months, and i dont have any luggage bags..
    Will have a Renntec luggage rack fitted to my 09 blade - what bags do you recommend i get to get my luggage into without them looking too bulky - will be looking to buy second hand..
    Thanks
  2. RepsolSam
  3. Barstewardsquad
    Kriega. Get a US20 and a US10 or two. They combine nicely and are fully waterproof.
    Others will say to go the Ventura route but you would then need to buy their rack as well.
  4. julestys
    julestys Active Member
    I have Kriega US20 and US10 and they are superb.
    They hold a good amount too.
    Did France and Ireland last year found quite a bit of rain and the luggage stayed bone dry
  5. RepsolSam
    They are bloody expensive though...
  6. Barstewardsquad
    Buy cheap buy twice. Kriega aren't cheap but they are good. Had mine nearly 6 years now and never had a problem.
  7. RepsolSam
    Oxford bags are not cheap new..
    Not sure if 2 kriega bags will hold 7 days worth of stuff...?
  8. beavis
    beavis Active Member
    Defo Kriega , I did a 4 day tour of Ireland with a 20+10 and was no probs. I've also been to the iom twice for 5 days and again no probs. expensive but worth it.
  9. RepsolSam
    Looking at the pictures...they open from the top..and not at the widest part...if that makes sense...is that right?
    So will need to be emptied to get to the bottom (as its very narrow)?
  10. RRoss
    RRoss Active Member
    +1 on the Kriega,got the renntec rack to fit the bigger bags and tank strap to fit us10.
  11. beavis
    Yes need to be opened from the top as it's a roll top which makes it waterproof. And yes if will need to be emptied to get to the bottom. Put what you need at the top then you won't need to get to the bottom !
  12. Silverback
    Silverback Member
    I am in the Kriega camp ! And yes they are effectively a very well designed and made roll top dry bag with a brilliant and very secure modular connection system.
  13. RepsolSam
    Okay..so looking at the a kriega not sure if I should do US30 and US10?
    Or is 20 & 10 ok?
    I will have a renntec RAC fitted - would these two strap to the rack? I guess I will have space for another rucksack too..?
    How narrow is the Kriega bag opening? Will I have to squash up everything? Thinking about creasing my clothes...?
  14. RepsolSam
    Also anyone got any pictures of these fitted on a blade?
    Thanks
  15. RRoss
    RRoss Active Member
    Just do the us30 unless you want to have stuff in separate bags. Plenty room left to attach a rucksack on the rack too. The kriega attachment loops go onto the rack so no tugging on the rear seat pad. Search renntec rack threads,am sure there's a picture of a blade loaded up with kriega.
    Update... It's the Kriega Q's thread,pics of sinewaves bike with it all fitted.
    #15 RRoss, May 12, 2014
  16. The.kickboxer
    The.kickboxer Active Member
    The newest Kriega is even better with the hook end straps. I have a 20 and two 10s on the side of it, also got a 5 on a tank adaptor. The tank straps fit better if you fit some double ended studs instead of the front tank bolts.
  17. RRoss
    RRoss Active Member
  18. rewy..rr
    rewy..rr Active Member
    US 20 with US 10
    US20 and US 10 Route Napoleon Sept 2013 (6 day trip)
  19. sinewave
    I'm getting embarrassed about how many times these pictures have been posted but hey ho! :)
  20. Muffking
    I dont see why. Its no worse than this :eek:
