Urgent Exhaust Clamp Q
Discussion in 'General 1000RR Discussion' started by RepsolSam, May 9, 2014.
  1. RepsolSam
    RepsolSam Well-Known Member
    Hi,
    Anyone know what size clamp this is? i need one..Honda want £28 - thinking any clamp would do...right?
    for a 05 blade
  2. HRCTrev09
    HRCTrev09 Well-Known Member
    Measure the diameter mate then check out eBay for exhaust clamps there's an abundance of stainless steel items in various sizes for just a few quid! That's what I done for my CB1's exhaust ;)
    Just measure the width across the pipe and bob's your knob :D
    Or Honda should tell you what size clamp you need the just order of eBay!
    #2 HRCTrev09, May 9, 2014
  3. RepsolSam
    i called honda - they said they dont know the size..
    not at home..needed to get the clamp on today.. may leave work early to measure up..
    think i can get one from like bnq? or homebase?
  4. Ian E
    Ian E Active Member
    Where are you based? I have a genuine Honda one brand new.
  5. megawatt
    megawatt Well-Known Member
    You need to measure the outside diameter of the sealing ring or inside diameter of the part of the zorst that it slides into. A u clamp will do for emergency use.
  6. sps170373
    Halfords sell bike exhaust clamps in different sizes
  7. mikegml
    mikegml Active Member
    It's 60mm.
  8. RepsolSam
    Thanks...got one from Halfords...all fitted
  9. 5455james1
    5455james1 Active Member
    Halfords or Wicks?
  10. RepsolSam
    got it from halfords..£1.45 :D
