Odd tyre ware
Discussion in 'General 1000RR Discussion' started by Jbully_uk, May 5, 2014.
  1. Jbully_uk
    Jbully_uk New Member
    View attachment 21191 View attachment 21192 View attachment 21193
    Not sure what has caused this issue but i'm a little worried about my front tyre.
    In the photo there are some odd welts in the rubber, this doesn't look normal to me and wondered if anyone could shed some light on this , have they seen if before ?
    the second issue as is a little hard to see, one side of the groove is well above the ware marker but on the other side its not far from the top of the marker, i cant understand how one side has worn lower than the other.
  2. kev.b
    kev.b Well-Known Member
    Looks pretty normal my 06 blade front tyre always wear,s the same on every front tyre I use.
  3. all the gear
    all the gear New Member
    they are the wear indicators
  4. all the gear
    oops ,just read the whole thing ,soz
  5. Ritchierich
    Ritchierich Elite Member
  6. Silverback
    Silverback Member
    I've just come back from a 2,300 mile Euro trip with a pillion on the back. My front was worn in the same way. Whilst the hard compound cetre of the tyre was hardly eroded, the softer rubber of the side section was very worn indeed.
    I was doing quite a lot of hard riding in the Vosges and braking fairly hard into tight hairpins with the bike at fairly extreme angles. This obviously made the sides of the front tyre work rather hard and I think that caused the unusual amount of side wear. The added weight of a pillion and full luggage did not help !
    If your riding style involves trail braking into corners, you can expect to see wear like this. If it does not....there may be an issue with your suspension set up and I would also check your front wheel bearings.
  7. Jbully_uk
    Thanks to silverback and Ritchierich.
    I do use the back break more than I do the front trying to keep the ride smooth as the front dips quite a bit under heavy breaking.
    Already had the bike booked in for suspension set up with PDQ in maidenhead.
    thanks again guys
  8. 5455james1
    5455james1 Active Member
    Pick up some new Sportsmarts
  9. Jbully_uk
    After talking to PDQ and having the Suspension setup ( minor adjustments) looks like your right james, 2k front and back and the tires are shot :) and they are Sportsmarts, any comments on new tires ? I liked these but at 2k on a set they arn't cheap.
  10. Jamiestrada
    Michelin PR4 are great and wear well IMO :)
    You should get 4k from what I have been told
  11. Jbully_uk
    But being a little bit of a tart Im not sure that I like the looks of the PR4's on a blade I has the PR3's on my Daytona and really got on with them but it was an older bike with a lot less power
  12. Jimbo Vills
    They do look pants, but they grow on you lol
    As for power, never had an issue with them not putting power down.
