Looking for a quiet Lid
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolSam, May 17, 2014.
  1. RepsolSam
    RepsolSam Well-Known Member
  2. sps170373
    Schuberth's have a great reputation for being quiet, from experience shoei aren't bad but arai are noisy
  3. r1monkey
    r1monkey Active Member
    was thinking the same myself.we should be able to try a helmet on the road before lashing out that sort of money.
  4. julestys
    julestys Active Member
    May seem an odd suggestion but how about good ear protection?
    That way helmet will be quiet too?
    I am going down the Ultimate Ear route, expensive altho I have had an ear op and don't want them getting any worse.
  5. r1monkey
    tried loads of different earplugs find them all painful and distracting after about half an hour .even tried the ones that mould to your ear shape, they have long since gone in the bin.
  6. julestys
    Oh dear thats not good
    I hope my moulded ones are ok cost a lot of dollar
    My Shoei is a quiet lid (Qwest) and will prob go for the GT Air next
  7. martinowen
    Xspirit 2 I find quiet
  8. Barstewardsquad
    As others have said Schuburth are always rated as a quite lid.
    As for ear plugs I used to wear ultimate ears, the ones with built in headphones, but ears changed shape and after 4 years they didn't work as well. I now use Shure SE215 headphones with Comply P Series tips so that I can have scamera alerts and gps directions from my mobile.
  9. Pete H
    Pete H Active Member
    I've tried most brands over the years, the schuberth is definitely the quietest, the arai is a better fit but noisier and the latest one a shoei gt air has a bloody air brake sized vent on top of it which causes whistling when you lift out of the bubble.
    My solution is ACS hearing defenders, custom moulded in a nice soft rubber with a tiny loop to remove them, used by lots of pro riders and f1 types, cost about £120. The proof is in the fact that I get annually hearing checked at work, and haven't had a drop in hearing ability since I started using them about ten years ago.
    Plus I got to see the inside of Suzi Perry's ear.
  10. mikegml
    mikegml Active Member
    I have a Schuberth C3 which is quiet, plus it's small and light.
  11. sauluk
    sauluk New Member
    Not an RX7 GP... Can't you just wear earplugs and get whatever you want?
  12. porcpen
    porcpen New Member
    Always had Shoei until I tried the Schubert SR1.......wouldn't go back.....
  13. BlackDevil
  14. RepsolSam
  15. r1monkey
    there is a small one on ebay for £419.00
  16. all the gear
    all the gear New Member
    I found my xr1100 was much better with ear pads in ,only £5 delivered on ebay .I was going to try the whisper strip next but didn't feel the need after buying the ear pads
