Fitting a new no. plate
Discussion in 'Maintenance' started by Julian, May 17, 2014.
  1. Julian
    Julian Active Member
    suggestions please on how to fit a 7x5 to an R+G tail tidy without drilling the no. plate :confused:
    if I have to drill it it's going to look hideous :mad:
    thanks
  2. graemewalker
    graemewalker Elite Member
    Double sided number plate tape all day cheap on eBay about two quid for a 5 mwr roll
  3. Julian
    that deal with gusts of 150mph+ Graeme ;):)
  4. graemewalker
    You can't pull it off with your hands well u can put with considerable force will outlast any speed u can do trust me
  5. Julian
    Thanks Graeme
  6. Fudster
    Fudster Active Member
    Agree with Graeme, double sided sticky tape is the best way to go as long as both faces are clean when you stick it on ..... they could hold ships together with the stuff :D
  7. SimonRR
    SimonRR God Like
    Measure and drill is easy and far safer, that's what I did :)
  8. rewy..rr
    rewy..rr Active Member
    Velcro worth considering too
  9. graemewalker
    Plate will come off with Velcro at high speed
  10. rewy..rr
    I have never had a problem using Velcro. Industrial strength stuff 2" deep and full width of plate.
    I have not used on a 7 x 5 though
  11. SimonRR
    SimonRR God Like
    What max speed you had with Velcro? I prefer the plastic bolts myself and Not hard to fit either?
    Simon
  12. Fudster
    Why velcro :confused: or am I missing something ....... well apart from the obvious :D
  13. SimonRR
    SimonRR God Like
    Perhaps he's hoping it will blow off at high speed, just before the speed camera ;)
  14. Fudster
    And then get done for perverting the course of justice :eek:
  15. SimonRR
    SimonRR God Like
    Velcro seems strange to me too, why not just use the plastic bolts it comes with ;) sorted :)
  16. BoroRich
    BoroRich Elite Member
    Mine's velcroed on too. Didn't budge at an indicated 175 mph.
  17. SimonRR
    SimonRR God Like
    so far... ;)
  18. BoroRich
    Well it's been on there for 2 years so I'd wager that if it ain't come off yet then it ain't going to :D
  19. SimonRR
    SimonRR God Like
    I would be also worried about someone knicking it while parked myself too? whats wrong with good old bolts and a drill? :D :eek:
    maybe I'm just "old school" :eek: :D
  20. BoroRich
    Because a couple of plastic bolts will deter the most determined of thieves won't they :D
    Also mine's only ever parked in a locked garage.
    I've got nothing against bolts and a drill. I'm just lazy and didn't want to take the time to line it all up and then risk messing up the numberplate by doing it wrong. That actually happened before when I was drilling a plate before. When the drill went through it lifted the printed part away from the plastic plate.
    With velcro you just cut a length and stick it on. Hasn't budged. Never looks like it's hanging off. No bolt holes in the plate. If your plate's looking tatty and you want a new one you just get it and stick a new piece of corresponding velcro onto the new plate and bang it on there.
