New Belly Pan Lower Cowl - CBR1000RR Fireblade - Gloss Black - 2008-2011
Discussion in 'Parts, Accessories & Clothing' started by Torch'd, May 15, 2014.
  1. Torch'd
    Torch'd Active Member
    Up for sale is a new belly pan under cowl for the Fireblade from 2008 to 2011. Finished in lovely deep Honda Black and then lacquered with 4 coats for a deep gloss finish, it is in mint new condition. Great addition instead of the standard grey belly pan that is fitted to some bike's. A new belly pan from Honda UK is £254.41, so easily the best bargain to be had in new condition.
    Fit it straight to the bike, and help me raise funds for my charity cycle ride, Wave 105 Cash for Kids Cycle Madagascar.
    £100 + £15.00 PP (large boxed by courier 2-3 days)
    #1 Torch'd, May 15, 2014
  2. Torch'd
    ...................£90 + £15.00 PP (large boxed by courier 2-3 days)
  3. ColinBR
    How does the paint cope with the bending required to fit and remove it from the bike?
    May be interested.
  4. Torch'd
    Bending....?? I have had to remove mine quite a lot recently after my bike was vandalised, the only original part left is the black belly pan, with Repsol decals and loads more of lacquer on top than this one because of the decals. But, bending it a lot is not required to remove it from the side fairings, plus after this one was finished, the guy was holding it one side and letting it wobble up n down. Because I know that IF you put too many layers on bike plastics, it can crack.
    The Repsol belly pan on mine is mint so I can only say its fine!! Naturally if you drop kick it across the garage, it might crack the lacquer, and break the dam thing!!!
  5. Torch'd
    BELLY PAN SOLD Off site!
