Shoei GT steaming up
Discussion in 'Mods, Upgrades, Accessories and Products' started by gray, May 26, 2014.
  1. gray
    gray Active Member
    Help please guys
    Have a shoei GT wanderer , fitted pinlock , problem even with all the vents open it's steaming up
    Where am I going wrong,
  2. Barstewardsquad
    Do you have a pinlock fitted?
    EDIT - Sorry didn't read properly. Would guess the pinlock is not fitted correctly. remove it, clean seals and refit.
    #2 Barstewardsquad, May 26, 2014
  3. martinowen
    Did you clean the visor before fitting the pollock as maybe damp causing it
    Did you put it in the right way?
  4. The.kickboxer
    The.kickboxer Active Member
    Is the pin lock in the right way round? Needs to be with the silicon seal towards the visor, so that the 2 layers do NOT touch anywhere.
  5. gray
    gray Active Member
    Update , been out tonight and pinlock is fine , it's the bloody internal sin visor steaming up any tips to stop this guys ,
  6. luker
    luker New Member
    Had a similar problem with mine, main visor no problems, sun visor was 'cloudy' and steamed up easy.
    I took the sun visor out and cleaned it with soapy water, dried, refitted. All has been good since.
    Luke
  7. M3NTALIST
    M3NTALIST New Member
    You can get a spray that stops fogging. Type "anti fog spray" into eBay and loads will come up.
    Andy B
  8. gray
    gray Active Member
    Thanks gents
