Running problems
Discussion in 'Maintenance' started by morpheus20170, May 7, 2014.
  1. morpheus20170
    morpheus20170 Active Member
    Sorry Stevie?
  2. bandit_287
    bandit_287 Active Member
    I've never supported the weight of the engine when removing either of my R&G crash bungs? Mines an 04RR though so yours may be different.
  3. morpheus20170
    I very much doubt it bandit. Thanks for the reply mate.
  4. morpheus20170
    Quick update. I've cut the block connectors off and for the time being used bullet connectors to connect the 3 yellow wires from stator to RR. I don't know where to find suitable connectors or whether to just connect them straight? Your views would be appreciated.
  5. Haggler ®™
    Haggler ®™ Active Member
    Solder them together.................if you need to separate them at a later date then just Un-solder them.
