ABS rear peg removal
Discussion in 'General 1000RR Discussion' started by Dif950, Jun 13, 2014.
  1. Dif950
    Dif950 Active Member
    Hi all,
    I've read several posts regarding the peg removal but I haven't seen any that have ABS.
    Is it basically the same job or do you go about it in a different way?
    Thanks in advance
  2. billo01
    billo01 Member
    Going from my sketchy memory it's basically the same procedure. I studied the guides on here then went for it and followed my own path. It's straight forward enough. Racking my memory now, I may had to free up the bracket holding the pipework in place that's located between the seat and rear brake but that was all I think. It's the small block that has the solid pipes connected to it and there's a plastic cover on the front.
    good luck anyway
  3. Dif950
    Thanks for the reply, thinking about tackling this but don't want to have a stripped bike for the summer! I've looked at the guides and am going with the 2 hour plus timescale as I'm not handy with spanners...
  4. Dif950
    Was delighted to buy a tinted high screen which I fitted last night, even though I was super careful with the lower tabs on the fairing, I still managed to snap one?! Not filling me full of confidence to remove the pegs :rolleyes:
  5. Repsol Rob
    Repsol Rob Elite Member
    WHATTTTTTTTTTTTTT you broke it already..... those bloody tabs are a pain ! ;)
  6. Repsol Rob
  7. Dif950
    Hahaha yeah I know, screen is ok but tab is now annoying me when on the bike.
    I'd have super glued the tab back on, but it fell into the fairing never to be seen again. Given my cac handed effort with the screen replacement, I don't fancy my chances of removing/ refitting the front fairing without breaking anything else...
  8. Dif950
  9. billo01
    billo01 Member
    I used this guide for reference, this guide removes the battery box and petrol tank if I remember rightly. Go the sub frame removal route it's a lot easier and use the hot bodies guide for removing the rear plastics. I was shatting myself at the thought of doing it on my 09 abs but it was a piece of piss in the end, just take the time. Worth it in the end though.
  10. ColinBR
    I just did mine today and fitted Sato hooks. No need to remove tank or battery box at all.
    Though this is the second time I've split the subframe. Which helps as you remember what to do.
  11. Dif950
    Thanks guys, going to have a go at this. I managed to fit a seat cowl without breaking anything, so has given me the confidence to strip the bike within an inch of its life :D
  12. Dif950
    Well I did it, many thanks for all the tips as it really gave me the confidence to do this job.
    Took me 2 hours exactly, and the only thing that gave me second thoughts was the 2 bolts holding the brake lines to the subframe, but once I worked out that it was only held by these bolts it was fine.
    Didn't put street hooks on as I wanted the pegs off today!
    May do this job again but not in any rush lol :)
  13. Dif950
  14. Dif950
  15. madmac
    madmac Well-Known Member
    Nice work fella - I'll be coming to you for tips when I remove the pegs from my ABS in a few weeks ;)
  16. Dif950
    My tips.
    Take photos of what you are removing so you have a guide when refitting.
    And....
    Buy street hooks before you do this job if you need them, as I really couldn't be bothered doing this again!
    I just had it in my head I wanted the pegs off so went for it. I'm sure I can tie the bike down somewhere else if I ever need to.
    Oh, and I'm feeling all smug that I actually did this myself :)
  17. sps170373
    If fitting sato street hooks make sure your buying the abs version otherwise you can't refit the footpegs to them
  18. ColinBR
    Buy the street hooks even if you don't want to use them for pillion pegs.
    The make an ideal anchoring point for travelling ;)
  19. madmac
    Yeah - unfortunately the ABS ones are £135 compared to £85 for the non-abs :(
  20. ColinBR
    Not if you buy them from the states ;)
    • Downvote Downvote x 1
