Anybody know or could take a look please, does the clutch cable hook into a plastic type fitting on top of the radiator on its way to/from the lever/clutch? Cheers Dan
Thanks for the quick reply, cheers. I thought so, had Honda do some work on the bike about two years ago and noticed then the clutch cable was sitting higher, about middle of the dash they must have broke it then... Just discovered now when I was putting all the standard fairing back on. Mind you I see they've since changed it in some form as the part number says now replaced with... Thanks again
No probs mate. Are you going to get parts to put it right or just leave it? It can't be much of a bother if it's been like that for a couple of years. That said, I'd probably want it sorted lol. Andy B
It's been sat for two years not used it now I know what it is I'll have to get it fixed need to order a couple of screws as well that I put safe...somewhere?!
