New 2010 Repsol Rep owner (sorry negative post)
Discussion in 'New Members' started by jaymzb, Jun 23, 2014.
  1. jaymzb
    jaymzb New Member
    Hi Guys, had my Blade for a week now, love the power. But its a 2010 model only done 2300 miles and in the past couple of years and has been pretty much sat in a garage on trickle charge only gone out for its first MOT.
    It has its first service stamped at 700 miles but nothing since 2010. Today my ABS light started blinking after riding the bike for about 45 miles to work. Is there a thread on here about this problem, or do you guys reckon its just because it needs a service and the brake fluid changing which should be done every two years according to Honda. And the fact its been sat for years and now is being heavily used.
    Thanks sorry to bring bad posts as my first, hopefully an easy remedy and future posts will be nothing but positive.
  2. si1000repsol
    Hi and welcome.
    I opted for the non abs model. Someone will be here shortly who can help.
  3. jaymzb
    jaymzb New Member
    She looks amazing though.
  4. si1000repsol
    Very nice!
  5. Pete H
    Pete H Active Member
    Welcome to the forum fella, unfortunately you're in a not so select club of people with abs issues, the flashing light one was raised here;
    http://1000rr.co.uk/general-1000rr-discussion/11657.htm
    But there's been plenty of discussion about it all over the site. It appears that your flashy light one means the system will show an error code to the ecu system telling it that the system needs to be re bled etc, but have a read for yourself. Use the search function at the top right for abs faults and you'll find dozens of hits.
    Hopefully a bleed will sort it.
  6. Barstewardsquad
  7. bradt
    bradt Elite Member
    Hi Jay welcome to the forum, sure someone on here will be able to help you out. Great looking bike
  8. jaymzb
    jaymzb New Member
    Thanks for the replys guys. It was fine on my way home. I wouldnt have bothered paying the problem if the guys in the service department had been in today at work as I work for a Honda dealer. But just wanted to know if I was unique or if it was a common problem. Will get the ecu checked tomorrow. Thanks again
  9. jmatt
    jmatt New Member
    Hi and welcome
  10. sps170373
    Welcome to the forum mate, any fault code is worth getting checked out
  11. madmac
    madmac Well-Known Member
    Welcome - great bike and like you I have similar issues with ABS light flashing. Hopefully a full ABS bleed is all it needs. Unlike you I don't work in a Honda dealer :(
  12. marco s
    marco s Active Member
    Hi and welcome . .
  13. jaymzb
    jaymzb New Member
    You are right, I am getting the guys at work to plug it in today. Probably just from lack of use, I can see me getting serious points on this thing though, so much different to my CBR600F.
  14. Remal
    Welcome to the forum. not much help but my 2011 ABS has 7000 miles on it now. been on many trackdays, Euro tour and blat's out and not had a brake bleed yet or any issues. So no help from me but welcome.
    Wondering now when the ABS needs to be bled?
  15. jaymzb
    jaymzb New Member
    Well according to honda they recommend you replace the brake fluid on a blade every two years. But talking to the teccy at work fluid changes on an abs blade are a nightmare for them and for your wallet lol we add an extra 4 hours labour over a non abs model apprently :(
  16. BlackDevil
    Hi and welcome!
  17. madmac
    Your Techs have obviously not heard of the mythical "special tool" then...;) :D
    Cuts the job down to 2 hours so I'm told...
  18. Cornish
    Cornish Active Member
    Nice bike, hope the problem is intermittent
  19. Frost1
    Frost1 Active Member
    Welcome, need to sort the ABS cos them Repsols are soooo quick :D
    Nice looking bike :)
  20. Rdr
    Rdr New Member
    Did you get the ABS problem sorted?
    Welcome to the forum by the way
