Oil experiment concluded!
Discussion in 'Maintenance' started by HRCTrev09, Jun 16, 2014.
  1. lambchops
    lambchops Elite Member
    I went for the pro 4 oil, 10w - 40. Put it in yesterday not ridden it yet mind.
    Worried me above with the offroad statement, looked at their website its under 4 stoke racing oils so is onroad.. Plus theres an S1000RR on the bottle :) Perhaps theres a pro 4 offroad also?
    http://www.fuchslubricants.com/racing-4-stroke-engine-oils
  2. maxxuk
    maxxuk New Member
    Hope it's ok, chances are it is.
    I used their 'oil advisor' Fuchs Product Recommendation you just put your bike make, type and year in.
    For my 2006 Blade, it spat out the following:
    Category name : Motorcycles, Scooters, Mopeds, Quads (ATV)
    Make : Honda
    Model : CBR (1987 - )
    Type : CBR 1000 RR Fireblade (2004 - 2007)
    Engine/transmission 6
    · Capacity : Capacity 3,8 litre Overhaul capacity
    : Capacity 3,1 litre
    : Filter 0,1 litre
    · Use : Normal
    · Intervals : Change 12000 km / 12 months
    · Product : SILKOLENE COMP 4 10W-40
    : SILKOLENE COMP 4 10W-30
    · Use : Initial service
    · Intervals : Change 1000 km
  3. lambchops
    Yeah sure it will be fine, was bought as a package from M&P with the filter for a CBR1000RR4. So looks like M&P need to change their package deal also!
  4. Jonnymac
    Jonnymac Active Member
    Well? How have you guys found it with the new oil in?
    I've got 4 litres of power 1 racing here I need to know if its going in?
  5. lambchops
    Well went out for a quick blat on mine but didnt notice any real difference yet.. Need longer to see if there's any fuel saving etc but engine note and gear selection feels as it was.. Mind the oil in there before had only done 1000 miles or so.. Only changed it as was worried had some metal filings etc from the rebuild project.
    Does seem very thin and runny.. Wondering if a slightly thicker viscosity would work better than 10w - 40 in the hot summer months.
  6. Jonnymac
    Cheers Lambchops. I'll probably use it up then. Just wait to see what the overall consensus is.
  7. lambchops
    If you have it then use it :) next time try the Energy or the correct oil not the off-road version like me lol
  8. maxxuk
    maxxuk New Member
    Have done some 200 miles since putting in the Comp4 10W30 on Saturday and I can definitely feel the difference in terms of smoother gear changes and slightly less vibration from the engine. Very happy with it! :)
  9. HRCTrev09
    HRCTrev09 Well-Known Member
    Hi guy that's been just over a fortnight I've had the Silkolene pro 4 energy in the Blade now and there is a definite difference in the amount of fuel I'm using not so much according to the trip computer but the miles I'm getting between fill ups so she's definitely using less fuel along with all the other benefits that come from this oil !
    I wasn't actually look for this but it must be the direct comparison with the two oils that shows it so clearly but all good!
    I've been using Silkolene energy for a couple of years now with no clutch issues at all and with better gear changes!
    Just thot I'd post a wee update :)
    #29 HRCTrev09, Jul 3, 2014
  10. maxxuk
    maxxuk New Member
    Thanks mate, that is indeed good and very useful info- I'd feel more inclined to test the PRO4 based on your reassuring feedback- can't beat first hand experience! :)
  11. RedMacGregor
    RedMacGregor Active Member
    Does the Silkolene make any difference in the amount of oil the engine burns??
  12. Slick
    slightly but only if you use 10w40
  13. HRCTrev09
    I haven't got an oil burner mate but to be fair I did use a bit of oil on track but I think that's quite common is your givin it a good workout ;)
  14. stujacks
    stujacks Active Member
    Hi Guys
    What grade should I use 10w40 or 10w30 or does it not matter.
    Cheers Stu
  15. Waterblade
    Waterblade New Member
    The oil debate never ends. TBH, with my Motul 5100 I use, it can feel fresh some days (gearbox feel) even with 5000km's on it, and some days feel clunky even if I have just done like 500km's on a fresh change.
    Doesn't really matter what high end oil you use. Unless there's some kind of lab analysis, it's pretty subjective.
