Fuel stabiliser
Discussion in 'Maintenance' started by Dano28, Jul 12, 2014.
  1. Dano28
    Dano28 Active Member
    Can anyone recommend a fuel stabiliser, bikes been sat for two years :( with same fuel... I've been running it up but not sure I'm going to get it back on the road this year so want to put some stabiliser in.
    Or am I too late, it doesn't have much fuel in, was going to put some more fuel in and add stabiliser.
  2. BlackDevil
  3. BlackDevil
  4. bonjo
    Dano
    you put the stabiliser in the tank before you mothball it!!
    I stored my bike for 1.5 year in a dry, room temperature area, with full tank of petrol and Sta-bil stabiliser. It worked like a treat.
    Unfortunately it is difficult to get this product in the UK now.
    If you plan another long term storage, empty the old fuel in there, you can try Putoline or Wurth but do it before you put the bike away.
  5. Barstewardsquad
    If fuel is 2 years old I would drain as much as possible; put a litre of fresh in; put the kill switch on and crank it over a few times; start it up and take it for a ride, or at least run the engine up to temp.
  6. Dano28
    Yeah I figured that, but now im panickin, been so busy with new job times flown and bike was never intended to be sat that long tbh, think I may be best draining the system and replacing with fresh fuel...
    How easy is this to do?
    Would I be ok just draining the tank and filling up with fresh?
    #6 Dano28, Jul 13, 2014
  7. Barstewardsquad
    Drain tank but don't fill it too much though. If you do have problems it is easier to remove a tank if it's not too full.
  8. Dano28
    Ok cheers I'll pick up a syphon today hopefully, bike starts fine, but think I'll get it all out to be on safe side and stick some fresh in.
    Hopefully it'll be back on the road in a month or two, just need to tax, MOT and ins.
  9. arthurbikemad
  10. Dano28
    Old fuel drained out 2 litres of BP Ultimate put in looks a nicer colour and peace of mind now.
    Picked up a £2.99 syphon from Halfords got almost everything out :)
  11. And7rp2
    And7rp2 Elite Member
    i use putoline fuel stabilizer from demon tweeks £7.98 in my gsxr and zx7r, fill the tank to the brim add stabilizer take it for a run to run thro system ,refill the tank job done,
    the GSXR had it in for 4yrs connected the battery she fired first time.
