F1 light 04 blade
Discussion in 'Maintenance' started by And7rp2, Jul 16, 2014.
  1. And7rp2
    And7rp2 Elite Member
    Ok, had the 04 track bike on the track today and after 1/4 mile the f1 light comes on
    Turn ignition off and it clears then 1/4 m it's on again
    The bike runs fine no issues at all, but would like to know what's causing it to come on ??
    Anyone know how to find the fault code on these bikes ?
  2. martinowen
    Could be where the exhaust cables where disconnected if done incorrectly or the servo bit may be faulty
    Well could be anything really
    Arthur!!!
  3. Barstewardsquad
    Next time the light comes on leave the engine running, into neutral and put the sidestand down. The light will then give a series of long and short flashes, the long flashes are 10sand the short flashes are 1s. So 3 long and 5 short flashes are 35, (which would be the exhaust servo and can be stopped with a servo buddy).
    If you don't have sidestand, or if you take the fairings off so you can get to the diag socket, you can short a couple of puns and it will show you all the codes in the ECU.
  4. And7rp2
    Ok I've not got the side stand if I find the plug what pins do I short ?
  5. sinewave
    The Red and the Black one!
  6. sinewave
    ..................sorry, I'll get me Coat!
  7. Barstewardsquad
    Can't remember the pins off the top of my head, but I have a diag plug so will let you know tomorrow.
  8. Jimbo Vills
    It's not the f1 mate it's fi - means frash it! Lol ;)
  9. Barstewardsquad
    Here's the business end of the plug that goes into the diag socket. The red bit circle the bit the clip locates in.
