Who sells Leo vince infill panel pls?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Dano28, Jul 22, 2014.
  1. Dano28
    Dano28 Active Member
    Who sells the Leo vince infill panel and how much are they?
    Thanks
    Dan
  2. HRCTrev09
    HRCTrev09 Well-Known Member
  3. Dano28
    Thanks mate, says for cb1000rr though will not fit cbr1000rr?
  4. Dano28
    Anyone with a full system got one fitted? As I see it bolts onto the link pipe just wondered if it still fits with the system rather than slipon?
  5. Jamiestrada
    I have just used two points one bracket is to engine case other to frame
    Seems solid enough use lock tight though or you get a horrible scraping noise around roundabouts .. That isn't your knee
    As I found out :(
    Here's pic of bracket that fits to engine and cover
    And fitted to bike I'd it helps
  6. Dano28
    Thanks Jamie, that should work fine, where did you get yours from?
    Detracting slightly just looking at your rearsets, when you spliced in the brake ligh switch to the oem wires, how far down up did you cut and join? Going to do mine at the weekend.
    Thanks
    Dan
  7. Jamiestrada
    About half way I then used heat shrink to tidy it up :)
    Got my cover of eBay from a lad who had sold his bike, I think JHS racing in Bristol could possibly help ? But heard they were stopping production of the cover
  8. Julian
    Julian Active Member
    JHS is a no
  9. barry107
    barry107 Active Member
