Gearbox notchy after oil change to full synthetic
Discussion in 'Maintenance' started by RedMacGregor, Jul 29, 2014.
  1. RedMacGregor
    RedMacGregor Active Member
    As Halfords had a special offer on Castrol Power 1 (full synthetic) I thought I would teat the bike to a change from the semi synthetic Castrol Power. This was three rides ago so about 500 - 600 miles since being changed. Initially I though the bike felt very smooth but this weekend I've had loads of dodgy gear changes - a couple of occasions where it would not drop into 1st gear and then revving the engine while in neutral and generally not the usual smooth changes I am used too. The only upside is that it would normally have burnt a small amount of oil but nothing so far.
    Has anyone else had similar problems using this oil?
    Thanks - Steve
  2. Repsol Rob
    Repsol Rob Elite Member
    #2 Repsol Rob, Jul 30, 2014
  3. HRCTrev09
    HRCTrev09 Well-Known Member
    Yes! Yes! Yes! Steve! Castrol is poo! :D I never understood why Honda recommends this oil :rolleyes: I know it's largely down to corporate deals and racing sponsorship but i suppose it's whoever gave Honda the most amount of dosh and nothing to do which oil suit the Blade best ;)
    #3 HRCTrev09, Jul 30, 2014
  4. Barstewardsquad
    and no that isn't the swear filter changing words ;)
  5. RedMacGregor
    Oh well so much for my bargain Castrol oil it's got to go for some of that super dooper silkolene energy stuff. Thanks chaps I'm glad that's all that the problem is. So strange as I've never had the problem with the old semi synthetic.
  6. Frost1
    Frost1 Active Member
    Pro 4 10w 40 in mine, lurvelly :)
  7. Iain
    Iain Active Member
    Rock Oil synthetic is worth a look if you can get it, used it on my 04 with good results.
  8. sinewave
