Exhaust puffing blue smoke out on full throttle opening
Discussion in 'General 1000RR Discussion' started by Scott, Jul 28, 2014.
  1. Scott
    Scott Active Member
    Me again hahha. My mate noticed it last week. What could it be ;)?
  2. Kentblade
    Expensive
  3. Barstewardsquad
    Blue smoke is normally oil.
  4. martinowen
    Yea I would say oil
  5. scooby
    scooby Elite Member
    could be over filled after an oil change,or worn rings,damaged barrels.
  6. Scott
    Scott Active Member
    Mmmm lovely. Definately not overfilled :(
    ... Shal wait for it to go bang ?
  7. Barstewardsquad
    Have you checked the exhaust for soot/sludge?
  8. Scott
    Scott Active Member
    No not yet. What will that indicate
  9. Barstewardsquad
    If it is burning oil I would expect to find some residue around the exhaust outlet and possibly nearby bodywork.
  10. Alblade
    Alblade God Like
    Its just one of the many oil burners - don't let it worry you, mine did it loads , had the rings replaced as it was drinking oil like nothing on earth - the oil use dropped but it still blew smoke at times.
    Mates have ripped the p!ss for years out of my bike - but the engine had no wear on any parts after 75k
  11. RepsolSam
    RepsolSam Well-Known Member
    must have been allot of smoke for you to notice when opening the throttle fully... ?
  12. Scott
    Scott Active Member
    Thsts a relief thanks
  13. foenix
    foenix Active Member
    If you open your engine, go with afetrmarket piston and a new cylinder block just changes the rings don't solve anything.
  14. Scott
    Scott Active Member
    Well I hope it's just extra oil really but if it does cock up. Il have a nova box and cams while there
  15. Tezza H
    Tezza H Active Member
    Does it smell like oil ? could it be over fueling on full throttle ? blocked or restricted airfilter ? bad map ?
