Gear Change indicator
Discussion in 'Mods, Upgrades, Accessories and Products' started by FozRB25, Aug 3, 2014.
  1. FozRB25
    FozRB25 Member
    Hi folks, just a quick one... I had a search but haven't been a able to find an answer. Can you recommend a good, reasonably priced Gear Change indicator please and where would be the beast place to get one?
    Muchas Gracias:)
  2. Slick
    the best one is the 12+ CBR;)
    I have a Gipro, easy to fit and calibrate. Think these work on engine revs and wheel speed, so there is alway a very short delay between changing gear and displaying it, also when stationary will not register i.e. if you're at the lights it will not confirm if you're in first.
    Can't speak for the others but you also have Acumen,PZRacing
  3. scooby
    scooby Elite Member
    yep the gipro is very good
  4. FozRB25
    FozRB25 Member
    Thanks for the info, gipro it is then. Seem a good price too :)
  5. Barstewardsquad
    +another for GiPro.
  6. allbutt55
    allbutt55 Member
    Just fitted a gipro got a used on off eBay for £40 best ones to go for easy to fit and set up
  7. bradt
    bradt Elite Member
    Agree gi pro
  8. RRoss
    RRoss Active Member
    Had the accumen on my 600RR,easy plug and play fit and setup,worked great.
  9. Mike07
    Mike07 Active Member
    GIPro + 1
    You can get set up ...install instructions online if you buy 2nd hand.
    Mike.
  10. BikersDiscountStore
    BikersDiscountStore Active Member
    There's a forum discount if you buy a GIpro from us :)
  11. sps170373
    Another here with GIpro very easy to instal and set up
  12. rosier1uk
    rosier1uk Active Member
    Got my gipro from biker discount store with forum discount excellent service
  13. Frost1
    Frost1 Active Member
    GIpro on mine, very good choice.
  14. SimonRR
    SimonRR God Like
    Yeah I use GiPro too, works very well :D
  15. FozRB25
    FozRB25 Member
    Thanks for all the advice folks.
    How much would it be from you please?;)
  16. BikersDiscountStore
    PM sent.
