Decent horn
Discussion in 'Mods, Upgrades, Accessories and Products' started by Lazywaster, Aug 2, 2014.
  1. Lazywaster
    Lazywaster New Member
    I'm sure all will agree the standard horn is pants. I almost avoid using it because the tiny 'parp' that comes out sounds like an embarrassment.
    Has anyone had any luck fitting some decent noise that's not too bulky or heavy?
  2. Stevie_d
    Stevie_d Senior Member
    Yeah I'd deffo like one that sounds like a car horn, standard is pants and sounds like it's powered by a 1.5 volt battery
  3. arthurbikemad
  4. Stevie_d
    Arf will that bolt straight on in place of standard honda item ?
  5. arthurbikemad
    You'd need a relay, worth while if you want loud!
    These are LOUD!!!!
  6. Stevie_d
    Ok what about summat a bit louder and not as extreme ?
  7. Stevie_d
    Surprised there's no jokers posted stuff like this normally does the trick !
  8. Stevie_d
    Arf is that 2 tone horn on fleebay an air horn with a miniature compressor at the side of it , hence the relay oh and it's gunna draw a lot of amps ?
  9. Lazywaster
  10. Pete H
    Pete H Active Member
    If you want a fairly straightforward fit, get a Wolo Loud One, about £15, 115db's.
    Fitted one to my last Fazer thou cos the OE was crap.
  11. Stevie_d
  12. Lazywaster
    Thanks guys the wolo horn look promising. I do like the mini compressor horn from fleabay too - just wondering where I can put the thing. I'll have a pole around the fairing tomorrow.
  13. Freedom of choice
    There is a guy I work with that swears by Cialis.
