Hi, Can anyone help out and show me where the plug and play loom fits to the 2008 'blade, as I can't easily see it Cheers...
Cheers guys, I just also got a reply back from Acumen, and yes apparently behind the LH fairing. I assume it is OK just to unplug the loom?
http://1000rr.co.uk/general-1000rr-discussion/15611.htm#post245994 should look like this, IIRC it has 4 terminals, (it is for the Gi pro anyways, apologies if it is different for the Acumen)
oh I was right then........ !! yes unplug and insert yours between the two.... then it will have a plug for your indicator to plug into.....(those looms are like rocking horse shite to get hold of).....
Cheers, Should be OK with the set up as I had one on an old bike, and the set up process is still on the website, but you never know....
