PCV on an RR7
Discussion in 'Mods, Upgrades, Accessories and Products' started by GappySmeg, Aug 15, 2014.
  1. GappySmeg
    GappySmeg Well-Known Member
    Just won a PCV + o2 eliminator on ebay... do they come with decent fitting instructions?
    Any advice or gotchas regarding fitting?
  2. scooby
    scooby Elite Member
    quite easy to fit,it's only a matter of 2 plugs to swap over (from memory at least) and the instructions where fine,but being a man and all that,i chucked em' in'tbin and cracked on :)
  3. GappySmeg
    Cheers scoob... am I right in thinking the tank and airbox needs to be removed?
  4. Hudson
    Hudson Active Member
    My CB1000R is currently with Dynojet in Preston and they said they do remove the tank as it makes it a lot easier and its best for routing the cables etc.... not sure if the Blade will be any different.
  5. RedBull
    RedBull Member
    Hi Hudson.
    I added a PC V on my 06 blade. I have a Akropovic carbon can with a pipercross air filter. Like you, I wasn't sure if I would feel any difference? I still can't now. I think the only way to resolve the issue. Is to have your bike Dyno tested and then have a custom map.
    I've just added dual projector headlights with angel eyes too. I was so fed up of having just one low beam :( looks far better and i can see - wohoo
    ps - thanks for adding me as a friend.
    cheers
