  1. Hondaboy63
    Hondaboy63 Active Member
    Hi what exhaust have you got on the bike.
  2. Hondaboy63
    Hi what exhaust have you got.
  3. andyb525
    andyb525 Active Member
    Hi. Its the MGP Growler from Hotbodies. I wanted a fairly cheap slip on until I could afford something else.
    It's done the job but will soon be time to go. I'm going to miss it, what a noise.
    Honda, 2012-14 CBR1000RR, MGP Exhausts, Hotbodies Racing
  4. Toth
    Toth New Member
    Took it down to the local bike dealer who is going to sell it for me :( so going to start looking for something more akin to the old man that I am CB1000r is hot on the list main criteria is more upright riding but must go like F**k;)
  5. BlackDevil
    BMW S1000R, make a test ride !
  6. Toth
    Toth New Member
    Oh you nasty man I'm not that old...... but I suppose you get a free pipe and slippers with a BMW so might be worth a look..
  7. GappySmeg
    GappySmeg Well-Known Member
    Just finished putting bike back together, having fitted a PCV, o2 eliminator, and map switch.
    Then put 2 maps on (baffle in, baffle out) and calibrated the throttle position. Started it up, and all ran perfectly, including switching maps via my home-bodged rocker switch.
    So...... came inside to get togged up for a test ride, and it starts chucking it down! It's been gloriously sunny all morning whilst I've been in the garage... bollox!!!
  8. Womblewizard
    Womblewizard Active Member
    Went for a good blast this morning, hoping to do the same tomorrow!
    But Tyre says No!
  9. ColinBR
    Finally managed to remove a large blob of tar off of my rear tyre, that I picked up in Spain during tour.
    What an utter pain in the ass that was !
  10. GappySmeg
    Finally got out for a test ride... and WHAT A DIFFERENCE. The uncertainty below 5k has gone, and the low-down torque is back! (Always suspected that, having removed the OE exhaust and thence exhaust valve, the sub-5k fuelling had been f*&Ked).
    All the way through the revs feels smoother and keener. Not overly sure there's any more outright power, but that wasn't the aim of the exercise... this was operation "restore smoothness"!
    Taking slow speed roundabouts is so much easier now that I can be confident in the power delivery at lower RPMs.
    Stopped halfway to remove baffle, flick my map switch, and try "baffle-out mode" (which was silly, as removing a roasting hot baffle was always going to result in singed fingers!)
    I had tried running without the baffle prior to fitting the PCV, and although the noise was highly agreeable, the uncertainty in the fuelling was not. Now though, its SMOOOOOOOTH as you like all the way, with a very satisfying subtle pop and burble on the overrun.... and holy crap its loud!
    Probably the best £150 (and 5 hours in the garage) I've ever spent on a bike :D
  11. Dave V
    Dave V Elite Member
    At last I got round to finish cleaning the bike and fitting the SP subframe[​IMG][​IMG][​IMG][​IMG][​IMG]
    Was planning on getting it coloured the same as the original, but kinda like the silver now it's on.
    • Like Like x 6
  12. Mad Matt
    Beautiful Dave.....
  13. Toth
    Toth New Member
    +1 agreed FB
  14. Barstewardsquad
    Adjusted the gear select lever down 1/2". Replaced the selector recently when I did my fairing, and despite measuring to its centre it was too high. First noticed the problem when I went for 2nd gear and got a bag of nails, but fixed it with a more "positive" flick of the foot. Can only guess that the bent rod I also replaced had reduced the amount of travel the selector needed to engage the next gear.
  15. si1000repsol
    Yes powder coated black would look great but still looks awesome!
  16. Souleh
    Souleh Active Member
  17. Dave V
    Dave V Elite Member
    After yesterday's cleaning gave the RRA a proper spanking.
  18. martinowen
    Oh dear what's happened there
  19. GappySmeg
    Got a bit carried away with the rotary polisher???
  20. Barstewardsquad
    Forgot to swap the scouring pad off the polisher?
